USB-C Rechargeable Pen-lights / torches
Discussion in 'Electronics & Electrics' started by Blinky, May 4, 2021.
  1. Blinky
    Blinky Member
    Jul 4, 2001
    3,302
    I'm looking for a simple 4 to 6"ish long rechargeable penlight.
    A Hi/Low setting, no flashing SOS stuff with complicated button press combinations. It doesn't even need to be waterproof as it's only for inside use.
    Just rechargeable without taking the battery out - USB-C would be ideal.
    The only torch I have leftover from the move back to Brissy is a Fenix TK41 and it's way too big!
    Any ideas?
  2. _zak
    _zak Member
    Oct 12, 2009
    393
    The 'arbitrary list of popular lights' on r/flashlight is probably the best place to look for suggestions. Quickly flicking through, it seems that of the ones you mention, the Wurkkos FC11 seems to be pretty close to what you're looking for, though it has a six modes rather than straight high/low.
    Blinky likes this.
  3. pfrcom
    pfrcom Member
    Aug 23, 2009
    447
    3114, Melbourne
    Nitecore Tip SE
  4. xc351
    xc351 Member
    Dec 30, 2005
    2,750
    i use a tti inspection light, its micro usb though.
    Blinky
    Blinky Member
    Jul 4, 2001
    3,302
