USB NAS possible?
Discussion in 'Storage & Backup' started by SSJX, Nov 23, 2006.
  1. SSJX
    SSJX Member
    Apr 16, 2006
    2,820
    I was wondering if I could get an external enclosure with both USB and eSATA, and then connect it to my wireless modem router (4 ethernet ports + 1 usb + wireless) via USB, would the drive show up as a network attached drive (after being formatted through a direct connection [usb or esata] with a pc)??
    Or should I go with a external enclosure with an ethernet port?
  2. Iceman
    Iceman Member
    6,647
    Brisbane (nth), Australia
    You might want to mention what router you actually have..
    Or just buy a synology ds-106e
  3. nux
    nux Member
    Jan 20, 2002
    16,780
    If the router supports that then yes you could.
  4. blakeyboysmith
    blakeyboysmith Member
    Dec 11, 2004
    379
    depends on the router...
    but if you use openwrt you can do something of the like...
    have a look at dansdata. he had a good article recently on nas solutions.
  5. stalin
    stalin (Taking a Break)
    Jun 26, 2001
    4,581
    On the move
    openwrt would probably do it, but i doubt it would be very fast, those routers dont have my grunt, and disk IO over USB combined with say ADSL2+ transfers would probably end up slowing one or the other down.
    SSJX
    SSJX Member
    Apr 16, 2006
    2,820
    i use a netcomm nb5plus4w modem router
    and im connected with adsl2+ :)
    SSJX
    SSJX Member
    Apr 16, 2006
    2,820
    my budget is about $200-250....
