USB power over ~7m
Discussion in 'Electronics & Electrics' started by BGH, Aug 17, 2017.
  1. BGH
    BGH Member
    Dec 16, 2004
    1,353
    You stay classy Melbourne
    I want to power a small security cam on my porch. What is the best/cheapest way to get USB power to it?
    DIY solution would be good. Would I be able to solder up a usb/network-cable solution?
  2. merlin13
    merlin13 Member
    Apr 12, 2003
    1,997
    back in BrizVegas
    Presumably you're getting the imaging back via Ethernet? If so then probably the cheapest way would probably be a pair of Power-over-Ethernet injectors, thence a suitable step-down power supply at the camera end (coupla dollars off eBay for something like one of these), or whatever's needed to give you reliable/stable +5 volts at the camera end.
    Best/easiest way would be a PoE camera, but probably not the cheapest option...
    If your camera is wireless for the imaging then mebbe a small solar panel 'n regulator, suitable battery and again one of those power supplies as above.
  3. dakiller
    8,070
    3844
  4. narkotix
    narkotix Member
    Oct 8, 2003
    518
  5. Renza
    Renza Member
    Dec 1, 2004
    4,711
    No need for anything that complex, its just for power, so get a couple of extension cables and join them together, or get some plugs/sockets and use whatever cabling in between
    BGH
    BGH Member
    Dec 16, 2004
    1,353
    Image is just coming back via wifi, so the cable I need is purely for power.
    At the moment I'm just leaning towards a 5m power extension cable and 2m usb cable. Was just hoping to hack something together with network cable so that I didn't have to waste an extension lead.
  7. Renza
    Renza Member
    Dec 1, 2004
    4,711
    get a USB cable, cut it in half, extend with any cable. Volt drop over a short distance like that won't be much as long as you don't use stupidly thin cable
