USB stick has "unknown" file system
Discussion in 'Storage & Backup' started by Blaktop, Jun 20, 2008.
  1. Blaktop
    Blaktop Member
    May 18, 2006
    48
    I just bought a new 4gb USB stick......when I plugged it in XP went through the usual, "new device detected.......your new device is now installed and ready to use" stuff, but when I click on it it tells me to "insert a disk into Drive J". Right click/Properties tells me:
    Type: Removable disk,
    File System: Unknown,
    Unused Space: 0 mb,
    Used Space: 0 mb,
    Capacity: 0 mb.
    If I Right Click and select Format I get the same "Insert a disk" message. My other USB stick lists the File System as FAT32.
    I've gone into Computer Management.....it is listed but treated like an optical drive with no DVD/CD in it. There are no options to format....only Change/Assign Drive Letter and Properties.
    Every other USB stick I've used has just plugged in, been recognised and usable straight away.......am I just being a noob and missing something simple or is it faulty.
  2. Mjölnir
    Mjölnir Member
    Apr 2, 2002
    803
    Do a low level format on it. The manufacturer of the device may have a tool on their site that'll do this, otherwise try downloading the Panasonic SDFormatter tool and try that. If you can't low-level format, it's probably faulty.
  3. bigheadache
    bigheadache Member
    Apr 23, 2005
    3,260
    Ever used it on Vista? Could be in the new exFAT format which is part of VIsta SP1
  4. Mjölnir
    Mjölnir Member
    Apr 2, 2002
    803
    If it was that, you still should be able to format it in Disk Management without getting an "Insert Disk" error.
