Usenet - DO NOT ASK FOR INVITES
Discussion in 'Networking, Telephony & Internet' started by Snoochems, May 13, 2011.
  1. Quadbox
    Quadbox Member
    6,334
    So... my nzb.su vip status just ran out. What's the current state of indexers? They've been adequate but not amazing, anything worth switching to from a performance/value perspective? I gave up on nzbget a couple of years ago because they had three months of retardedness
  2. waltermitty
    waltermitty Member
    Feb 19, 2016
    1,170
    BRISBANE
    DOGnzb is good but no pr0n
  3. Willo
    Willo Member
    Oct 11, 2002
    907
    Melbourne, Australia
    nzbgeek
  4. waltermitty
    waltermitty Member
    Feb 19, 2016
    1,170
    BRISBANE
    I have the following indexers, make of the table what you will.
  5. h0mer_
    h0mer_ Member
    Aug 6, 2008
    74
    Would have been really interesting if you also had a nzbgeek account in that mix :)
    What is the TL;DR on getting access to the omgwtfnzbs site?
    /I've got an nzbgeek account and it's okay for the most - however it fails on finding older stuff that has been DMCAd (manually poking around I can get by, just that it's, yeah, manually :D )
  6. Dr Evil
    Dr Evil Member
    Oct 20, 2010
    2,856
    Your failure rate of nzb.su seems rather high.
  7. iambarney
    iambarney New Member
    Mar 1, 2018
    5
    I too have been using Sonarr for the last 12 months and I have to admit, I'm really enjoying it's automation. I tried installed Radarr last night and I'm having an issue with mapping it to my network share drive. I recall having the same issue with Sonarr, but I've no idea how to get around it.
    I've tried the netowork path //DS1815/Media/Movies/ and I've also tried mapping it to my K:\ with no success. A quick Google tells me I need to run nzbdrone.exe which I did, but no luck.
    Any suggestions?
  8. waltermitty
    waltermitty Member
    Feb 19, 2016
    1,170
    BRISBANE
  9. iambarney
    Mar 1, 2018
    5
    Whoops. I've got my slashes leaning the wrong way, but the message remains the same.
    I did do something silly on this particular Windows PC where I think I've wonked the user accounts, but that doesn't answer the question as to why my Sonarr service works just fine? (it's pointed to \\DS1815\Media\TV)
  10. waltermitty
    waltermitty Member
    Feb 19, 2016
    1,170
    BRISBANE
    Which account is Sonarr running as? (check services.msc). Is there anything in the radarr logs (system tab)?
  11. iambarney
    Mar 1, 2018
    5
    Oddly enough, Sonarr doesn't appear in the list (but it's definitely running). Radarr is there and under "Log On As", it says Local System.
  12. waltermitty
    waltermitty Member
    Feb 19, 2016
    1,170
    BRISBANE
    Try changing Local System to your user account. Sonarr may be called NzbDrone in services.msc still.
    iambarney likes this.
  13. iambarney
    Mar 1, 2018
    5
    Boom! This did it! u da real mvp waltermitty. Thanks!
  14. Ravennoir
    Ravennoir Member
    May 1, 2007
    6,466
    Hey Guys,
    Im currently using Ninja News and recently i have getting alot of failures and slow downloads
    Anyone else on them getting the same issues ?
  15. waltermitty
    waltermitty Member
    Feb 19, 2016
    1,170
    BRISBANE
    No dramas here. I get a consistent 9.5mbps on my 100mbit connection. Minimal backup usage as well. Might be worth PM'ing the NewsgroupNinja dude on reddit https://www.reddit.com/user/slinxj
  16. Ravennoir
    Ravennoir Member
    May 1, 2007
    6,466
    Thanks, Ill see how i go
    UPDATE :
    wow thats some fast support, got the support email address from reddit and contacted them
    they worked out the issue was the port it was routing on, once I made this change its much better
  17. h2oxide
    h2oxide Member
    Dec 9, 2009
    3,754
    Excuse the slight thread revive.
    Mainly used for TV shows/movies? No NZBGeek? I'm surprised at the success rate of SimplyNZBs, and the failure rate of NZB.su; which provider backbone/s are you using?
  18. darknebula
    darknebula Member
    May 21, 2009
    1,077
    Frankston
    Using nzbs.in and nzbgeek, smooth sailing as always
  19. waltermitty
    waltermitty Member
    Feb 19, 2016
    1,170
    BRISBANE
    I had NZBGeek a long time ago but I think my premium expired. Yes, TV/Movies only really. I use newsgroup.ninja and usenet.farm.
  20. h0mer_
    h0mer_ Member
    Aug 6, 2008
    74
    Ninja is offering a 12 month upfront sub for $40 ($3.33/monthx12, yeah??). I'm guessing that that will be US$.
    I sent them an email to change me over from the obscene $7.99 I'm currently paying :D
    Dunno how long it's been this cheap, or how long it will last.
    Also:
    https://www.reddit.com/r/usenet/wiki/providerdeals is worth a look.
