Usenet - DO NOT ASK FOR INVITES
Discussion in 'Networking, Telephony & Internet' started by Snoochems, May 13, 2011.
  1. DuaNo
    DuaNo Member
    Feb 7, 2003
    608
    Might start looking into using usenet again
    elh9 likes this.
  2. DuaNo
    DuaNo Member
    Feb 7, 2003
    608
    Any sports like boxing or mma?
  3. AERO
    AERO Member
    Aug 30, 2001
    3,886
    albury 2640 nsw
    i ran out of my 2 blocks of data and havnt bought any for about 3 months since lol, i miss it but meh, just means i dont watch anything
  4. h0mer_
    h0mer_ Member
    Aug 6, 2008
    78
    Very quick response to my email - had a couple of replies from them last night, and all I had to do was simply enter 'specialdeal' in the promo/coupon code box on the upgrade page and that brought it down to the $40 yearly option. A few seconds later it was done.
    One of the easier usenet providers to deal with, in terms of their dashboard/portal interface. Very clean. Some are so clunky and downright hideous!
    I can see it was some time ago that you posted that, however if you see this - it might be worthwhile logging back into the NZBGeek and checking your account, as the initial premium accounts they offered/sold were lifelong, one-off payment deals. Soooo, you could still have an active account there??
  5. underskore
    underskore Member
    Nov 5, 2002
    4,254
    3198
    just did this - payment upfront instead of monthly... fingers crossed it's not a last minute exit scam, don't want those ninjas running off with my few extra $$
  6. h0mer_
    h0mer_ Member
    Aug 6, 2008
    78
    Yep. That's why when I signed up with them a few months ago I was happy with the pay by the month. But US$40 is half that rate, and so if it lasts six months... And it's not the end of the world if it does turn out to be a scam. And if it's not, it auto-renews at the cheap rate after 12 months as well.
    Should be ok :)
  7. downforce
    downforce Member
    Jun 11, 2007
    1,202
    Thornlie, WA
  8. Ravennoir
    Ravennoir Member
    May 1, 2007
    6,483
    Hey Everyone,
    I am currently using NewsgroupNinja and ive just switched over to NBN, but my download speeds are still only ~140-170KB/s
    Are there any settings I need to check to improve the speeds ?
  9. kbekus
    kbekus Member
    Aug 28, 2001
    1,183
    Pascoe Vale, Melbourne
    how many simultaneous threads are you downloading at? NGN allows up to 30 connections...
  10. Ravennoir
    Ravennoir Member
    May 1, 2007
    6,483
    I thought it was 50
    I have also tried with 30 as well, and still the same
  11. philquad
    philquad Member
    Jan 22, 2004
    1,279
    nelson bay
    i never new this thread, something i actually know about
    i use frugal usenet, 50 yr, only as newshosting gets so many duds
    i only use 8 bots, i can up to 50 threads, but i found theres no difference
    change ports if you have speed problems
    ng should run as fast as your little nbn can go, if not your host sucks
  12. Ravennoir
    Ravennoir Member
    May 1, 2007
    6,483
    Yeah i just found this about changing ports :
    https://www.jdhodges.com/blog/slow-nzb-download-speeds-fixed-solved/
    These are the ports available, but they dont seem to be making any difference
    UPDATE : So it seems to be an issue with my VPN (PIA), with the VPN disconnected, the speeds are expected, but if I connect they are back down to being slow
    philquad likes this.
  13. greencamel65
    greencamel65 Member
    Jan 17, 2003
    463
    Asgard
    i use PIA also. No issues. Maybe try a different vpn server?
  14. Ravennoir
    Ravennoir Member
    May 1, 2007
    6,483
    Which ISP are you with, im wondering if Aussie Broadband throttles PIA
  15. greencamel65
    greencamel65 Member
    Jan 17, 2003
    463
    Asgard
    Telstra Cable
  16. h0mer_
    h0mer_ Member
    Aug 6, 2008
    78
    Connect directly to the Usenet servers via their SSL ports... What do you gain by connecting via a VPN?
    TRG.dOinK and philquad like this.
  17. Ravennoir
    Ravennoir Member
    May 1, 2007
    6,483
    I guess just that added level of reassurance
  18. h0mer_
    h0mer_ Member
    Aug 6, 2008
    78
    Torrents, and other P2P protocols, yes for sure. Usenet, not so much...
    As long as you ensure your connections are over TLS you should be fine. And then you eliminate the VPN bottleneck potential.
  19. Acesi7
    Acesi7 Member
    May 25, 2009
    2,149
    You going through a VPN?
    Edit: Page has updated with more responses, weird... I had similar issues with the VPN. Ended up dropping it. Can't remember which VPN I was using. Had 100mb/s connection. Was getting attrocious speeds. Ditched the VPN, back to ~8MB/s
