Usenet - DO NOT ASK FOR INVITES
Discussion in 'Networking, Telephony & Internet' started by Snoochems, May 13, 2011.
  1. philquad
    philquad Member
    Jan 22, 2004
    920
    nelson bay
    i never new this thread, something i actually know about
    i use frugal usenet, 50 yr, only as newshosting gets so many duds
    i only use 8 bots, i can up to 50 threads, but i found theres no difference
    change ports if you have speed problems
    ng should run as fast as your little nbn can go, if not your host sucks
  2. Ravennoir
    Ravennoir Member
    May 1, 2007
    6,402
    Yeah i just found this about changing ports :
    https://www.jdhodges.com/blog/slow-nzb-download-speeds-fixed-solved/
    These are the ports available, but they dont seem to be making any difference
    UPDATE : So it seems to be an issue with my VPN (PIA), with the VPN disconnected, the speeds are expected, but if I connect they are back down to being slow
    philquad likes this.
  3. greencamel65
    greencamel65 Member
    Jan 17, 2003
    277
    Asgard
    i use PIA also. No issues. Maybe try a different vpn server?
  4. Ravennoir
    Ravennoir Member
    May 1, 2007
    6,402
    Which ISP are you with, im wondering if Aussie Broadband throttles PIA
  5. greencamel65
    greencamel65 Member
    Jan 17, 2003
    277
    Asgard
    Telstra Cable
  6. h0mer_
    h0mer_ Member
    Aug 6, 2008
    64
    Connect directly to the Usenet servers via their SSL ports... What do you gain by connecting via a VPN?
    TRG.dOinK and philquad like this.
  7. Ravennoir
    Ravennoir Member
    May 1, 2007
    6,402
    I guess just that added level of reassurance
  8. h0mer_
    h0mer_ Member
    Aug 6, 2008
    64
    Torrents, and other P2P protocols, yes for sure. Usenet, not so much...
    As long as you ensure your connections are over TLS you should be fine. And then you eliminate the VPN bottleneck potential.
  9. Acesi7
    Acesi7 Member
    May 25, 2009
    2,149
    You going through a VPN?
    Edit: Page has updated with more responses, weird... I had similar issues with the VPN. Ended up dropping it. Can't remember which VPN I was using. Had 100mb/s connection. Was getting attrocious speeds. Ditched the VPN, back to ~8MB/s
