Using air filters on computer fans for cleaner air
Discussion in 'Modding' started by laptop, Jan 29, 2019.
  1. laptop
    laptop Member
    Jan 15, 2015
    2
    I have 120mm fans on my computer so want to put some air filters on these fans for cleaner air.
    Has anyone tried this?
    Does anyone know where I can get 120mm air filters?
    I have heard that HEPA is good.
  2. Sphinx2000
    Sphinx2000 Member
    Sep 16, 2001
    6,544
  3. Jazper
    Jazper Member
    Jul 28, 2001
    2,468
    Melbourne Australia
    PVC dust filters work well at filtering dust, but not so well at other nasties. The problem with HEPA type filtering is that it creates restriction, so you need high static pressure fans. This can create noise.
  4. Beavis_Wolf
    Beavis_Wolf Member
    Sep 6, 2007
    71
    Adelaide SA
    HEPA filters are normally used in airconditioning for test/operating rooms etc pointless putting on a pc as they are for taking out minute particles and as your room is full of dust etc
    and they will block up very quickly
  5. Alby1976
    Alby1976 Member
    Mar 1, 2002
    1,482
    Mt Isa, again....
    Took the front cover off mine, and slid a stocking over it, yes I did feel weird when purchasing from Kmart.
    Seems to work a treat at keeping all the dust and cat hair out, as it is visibly stuck to the front of the case, pretty easy to clean too.
  6. Sunder
    Sunder Member
    Apr 26, 2012
    3,002
    You think that's weird? One time, when the the accessory belt driving the alternator went late at night, I went into a servo to get a replacement - but left the engine running in case there wasn't one of the right size. (Didn't want it to not start again). Left my two friends, two big burly guys in the car. There wasn't one the right size for the car, but there's a trick where you can twist and pull a stocking to high tension, and tie it to the pulleys. It won't drive a heavy load like an air conditioner, but it will drive smaller pulleys like alternators and power steering.
    I bought one, and got the strangest look from the cashier!
    Anyway, back on topic, the other trick is to lift your PC off the floor. I traveled with my PC through hotels on a road trip (So I could game with mates, after the kids have gone to bed). 3 days on the floor of a hotel room, which should be vacuumed every day, got more dust on it than a year sitting on my desk.
    laptop
    laptop Member
    Jan 15, 2015
    2
    Thanks for your replies,
    I noticed how much dust and such collect in my computer and it could definitely be improved. If it's in the computer it is also in my lungs which is probably not so good.
    I like that stocking idea.
  8. Sunder
    Sunder Member
    Apr 26, 2012
    3,002
    Your lungs have mucus membranes to stop a lot of this stuff getting in. But it depends on the size and nature of the particles. It's not the dust you can see that's a health hazard, but the tiny PM2.5s that you can't see that's an issue.
  9. Recharge
    Recharge Member
    Sep 5, 2001
    9,399
    I REALLY need to do this with my next build, 2 indoor border collies is a LOT of dust and hair in my pc and I'm sick of cleaning it :lol:
    next build being a all new zen 2 when they hit the market in sixish months.. HURRY UP!!!
  10. power
    56,695
    buy a chassis that is designed with filtration in mind. As in it's already there.
  11. Recharge
    Recharge Member
    Sep 5, 2001
    9,399
    thats what I was planning, as the time gets closer I's start seriously looking.
    most cases don't come with such filtering in mind unfortunately :/
  12. power
    56,695
    a lot of Fractal's have them, even the cheapies. I'd also recommend 140 over 120mm if you are getting something new - just that touch quieter.
  13. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    136,452
    Omicron Persei 8
    Can't go wrong, used it plenty of times before, works great.
  14. Leigh M
    Leigh M Member
    Jan 13, 2010
    2,045
    Western Sydney
    Fractal case has been the best case I've owned, multiple easy to remove dust filters that are vacuum friendly are awesome.
