Using air filters on computer fans for cleaner air
Discussion in 'Modding' started by laptop, Jan 29, 2019.
  1. Ratzz
    Ratzz Member
    Mar 13, 2013
    8,192
    Cheltenham East 3192
    DEMCI filters are so fine that I can actually see dust collect on them in as little as 48hrs. A visible circle, the size of the fan (or in my case, 3 140mm circles on a 3x140mm magnetic filter). All it takes to clean them is to literally just wipe your hand across them, it just rolls off easily. My house is clean, though sometimes a little untidy. Its amazing how much dust is in the air in even the cleanest environments.
    Hepa filters are completely unnecessary, but basic fine mesh filters are a must if you don't want to do the whole air compressor/brush declogging process every year. A clean computer, particularly clean fans and fan cooled heat sinks, runs a lot cooler. It astonishes me how some old machines I've fixed up for customers have even still been running, with dust turning heatsinks into solid blocks of dust and detritus.
    Alby1976 likes this.
  2. /invariance\
    /invariance\ Member
    May 23, 2012
    835
    pwlm1975 and Ratzz like this.
  3. Mr B
    Mr B Member
    Oct 27, 2015
    20
    I made a couple of little stands to keep the pc's off the floor - makes a big difference to the amount of dust they suck up.
  4. Groff
    Groff Member
    Jun 22, 2012
    102
    NSW
    This is so true. You can't even see any heatsink at all.
    Here's a before and after of the inside front of a case
    https://ibb.co/1G8gFLW
    https://ibb.co/kmx4h8r
