Using drano to clean my tubes :lol:
Discussion in 'Extreme and Water Cooling' started by Smoke87, Oct 9, 2008.
  1. Smoke87
    Smoke87 Member
    Jun 17, 2005
    6,195
    :lol:
    I have some kind of residue on the inside of my tubes, it may be algae, it may be muck. But I want to avoid having to buy new tubes :( And I don't care what they look like I just want it to be clean and not grow into something tha tmay cause a clog.
    So I'm thinking running drano through the system a few times then flushing it with litres of mineral water will be ok?
  2. Kaine[zof]
    Kaine[zof] Member
    Mar 22, 2004
    2,179
    You'll want to make sure the Drano isn't going to melt your tubing or anything. It could react badly. What kind of tubing do you have?
  3. Frag_Lord
    Frag_Lord Member
    Nov 23, 2004
    1,343
    Rag or something on a pipe cleaner :)
  4. n3wbi379
    n3wbi379 Member
    May 15, 2006
    4,618
    Melb
    I would just buy new tubes mate, thats wat i do.
    You dont want to damage ur tubes in any way.
    Upto u tho. :thumbup:
    Smoke87
    Smoke87 Member
    Jun 17, 2005
    6,195
    Actually....I think i will take your advice and get the new tubes.
  6. n3wbi379
    n3wbi379 Member
    May 15, 2006
    4,618
    Melb
    Good call...
    Nothing better then new tubes in ur system :D
  7. Terminatus
    Terminatus New Member
    Jun 10, 2008
    170
    try the drano first, just for schnitzengiggles.
  8. stuii
    stuii Member
    Mar 27, 2007
    1,489
    Templestowe
    I'd be more worried about your pump if your plannign to just run your loop to clean it... also you never know what particulate shit will be 'uncaked' and move to clog up some spot worse than where it was...
  9. petercr
    petercr Member
    Jan 4, 2002
    4,354
    Northern Brisvegas (4504)
    Given that any build-up is likely to be some sort of carbonate, a good rinse with hot water and vinegar should help before trying the 'stronger' stuff...
  10. Fischbitz
    Fischbitz Member
    Feb 10, 2003
    571
    Orange
    Why not try something a little less caustic like Eno's or sodium bicarbonate.
    Cheers :D
  11. mshagg
    mshagg Politburo
    May 8, 2007
    23,089
    Agreed... drain cleaner is a bit harsh!! Prob get a cpl of metres of tubing for the price of a tin of draino anyways.
    But have an experiment with the stuff you pull out?
  12. cdtoaster
    cdtoaster Member
    Jan 21, 2007
    4,768
    Tokara forest
    has anyone ever tried pool water? like leave it in overnight then wash it off. that has a variety of chemicals but its pretty mild
  13. OhFoRkMe
    OhFoRkMe Member
    Apr 27, 2005
    3,287
    Joyner 4500
    Im just hoping you are not female..
  14. n3wbi379
    n3wbi379 Member
    May 15, 2006
    4,618
    Melb
    ROFL ROFL :D
