using newer ram in older PCs
Discussion in 'Newbie Lounge' started by MotorAce, Dec 9, 2006.
  1. MotorAce
    MotorAce Member
    1,471
    AU
    im trying to source a 1gb stick of pc2100 ram for a relative but finding it difficult to do so. Generally can you use faster ram in older PCs or does it depend on the motherboard?
  2. sgtraven
    sgtraven Member
    Sep 10, 2004
    3,046
    Vic, Glenroy
    theoreticaly yes. all ddr ram is back compatable, but due to a lot of mb's being picky id say its one thing that you would be taking minimal risk on
  3. touchwood
    touchwood Member
    Feb 2, 2006
    8
    4870, Qld.
    You may find this site helpful mate....
  4. JonP
    JonP (Banned or Deleted)
    Nov 21, 2004
    1,859
    Bentley WA
    Ebay - heaps and cheap
  5. ShaneHm2
    ShaneHm2 Member
    Jan 29, 2002
    3,619
    depends the limitation is fsb of ur new cpu, i tried ddr 2100 with a celeron d 775 and it worked, but i think its more just of pot luck
  6. terrastrife
    terrastrife Member
    Jun 2, 2006
    18,818
    ADL/SA The Monopoly State
    ShaneHm2 try reading the original post next time.
    generally older boards will work with newer ram, as long as the total module size isnt too big or density is too high, so you have a good chance that a ddr400 512mb double sided stick will work, while a single sided one wont.
  7. ShaneHm2
    ShaneHm2 Member
    Jan 29, 2002
    3,619
    umm next time u post that read the rules that this a flame free zone. and i wrong the question the wrong way around my mistake.
    Also since i have now re read the post, to the OP make sure your motherboard supports 1gb sticks and if u have other sticks in there make sure if the new module needs to be single or double sided or if it doesnt matter. Also in terms of speed wise, all modules will be automatically be clocked down to the slowest module, ie
    dimm 1 = 256 mb of pc2100
    dimm 2 = 256 mb of pc2700
    dimm 3 = 512 mb of pc3200
    all modules there for will run at pc2100 speeds
  8. terrastrife
    terrastrife Member
    Jun 2, 2006
    18,818
    that wasnt a flame, just pointing out that your post was useless in regards to the original topic.
    THIS REPLY on the other hand may be considered a flame as it has nothing to do with anything...
    :D
