Using old modems are Wifi Repeaters/Access Points?
Discussion in 'Networking, Telephony & Internet' started by the_antipop, Jul 27, 2020.
  1. Symon
    Symon Castigat ridendo mores
    Apr 17, 2002
    4,764
    Brisbane QLD
    It's been a while for me as well but I recall having a hard time changing the IP address on those Telstra modems, it 'sort of' worked but there was weird stuff happening that went away if you set it back to the default IP.
    Pretty sure if you turn on bridge mode it will disable the WiFi on the modem.
  2. kogi
    kogi Member
    Jan 23, 2003
    4,827
    2031
    There is a thread about the telstra modem on whirlpool.
    What I remember from a brief scan. After taking out the sim card and and resetting, it will auto setup itself as a repeater/mesh.
    Shady memory, so best to read the thread yourself
  3. koopz
    koopz Member
    Dec 27, 2001
    2,130
    Qld
    // deleted.
    sorry wrong window
    check your IP tables and advise from there lads
    the_antipop
    the_antipop Member
    Jun 11, 2005
    2,185
    Gold Coast
    As you all predicted - I started to get issues running the 2 Gen 2 modems. I had them setup correctly, both spitting out wifi - but devices got confused between which one to connect to, and led to issues on my phone, PS4 and TV.
    Ended up getting a Kogan Wifi Mesh AC1200 3 pack for $109 delivered. Pretty cheap price. Will use the main unit in bridge mode, and then the 2 secondary units alongside my main Gen 2 modem. Happy days.
    Pugs likes this.
  5. Renza
    Renza Member
    Dec 1, 2004
    4,775
    You'll get this issue regardless if your APs don't talk to each other in a mesh or controller setup.
  6. Pugs
    Pugs Member
    Jan 20, 2008
    9,387
    Highbury, SA
    we should get a bookie evolved...
