Vesa wall mount patterns
Discussion in 'Audio Visual' started by Julz, Nov 10, 2024.
  1. Julz
    Julz Member
    Jul 4, 2001
    2,721
    Melbourne, Victoria
  2. mtma
    mtma Member
    Aug 12, 2009
    7,092
    I suppose it depends on the style of mount, for example the one you linked appears to be a kind that would be continuously variable width up to the maximum, but the holes of the vertical hangers do have some restrictions - however a 500 high pattern is mentioned so I would expect that there the holes in the vertical hangers have some position that can support a 500 high pattern without modification.
    However if the mount has some kind of fixed increment system (which you find more on pivot arms), that might not actually be the case.
    Julz likes this.
    Julz
    Julz Member
    Jul 4, 2001
    2,721
    Melbourne, Victoria
    Yep that's what I thought. Just don't want to buy the wrong mount and then have the installation guy say he can't install because the mount doesn't fit.
    There also seems to be massive variances in prices for brackets. Many can be 3-10 times the price of the cheapest without necessarily an equivalent uplift in quality or features.
  4. nico6
    nico6 Member
    Sep 9, 2005
    1,894
    melb.vic.au
    That mount will be fine. Easily wide enough, and the height goes to over 600mm along with longer/variable holes at the bottom which helps.
    The thing I usually find difficult is finding the right bolt thread and spacers for depth of thread. But your install guy should take care of that
    Julz and the_fuzz like this.
    Julz
    Julz Member
    Jul 4, 2001
    2,721
    Melbourne, Victoria
    Awesome thanks will order this one
