VIA vs. Realtek onboard sound
Discussion in 'PC Audio' started by Mau1wurf1977, May 14, 2009.
  1. Mau1wurf1977
    Jul 19, 2006
    13,706
    Country WA
    How does the VIA sound chip compared against Realtek.
    Most mainboards come with realtek, but some have the VIA VT1708. Any good?
  2. spAm^bOy
    spAm^bOy Member
    Jul 22, 2003
    457
    I'll chime in and say both are crap - spend $55 on a Xonar U1. It would be a marked improvement on either onboard solution.
  3. phreeky82
    phreeky82 Member
    Dec 10, 2002
    9,712
    Qld
    I don't have any with VIAs but I have a few with Realteks and am not impressed with them.
    The iMac has impressed me with audio quality (did I really say a mac impressed me? hmmm), I've seen conflicting reports about it using Realtek and Wolfson chips. :confused:
    Mau1wurf1977
    Jul 19, 2006
    13,706
    Country WA
    Well I had a X-Fi Xtreme Gamer before, and to be honest for Music and TV shows I can't tell the difference. I'm very happy with both.
    For games I know the X-Fi is better as it takes bit of work away from the CPU.
  5. terrastrife
    terrastrife Member
    Jun 2, 2006
    18,814
    ADL/SA The Monopoly State
    well if you mean the usual mp3s and tv rips of course its going to sound no different if the source is bad to begin with.
    but with a nice flac or bd and some nice headphones theres night and day difference between a cheap xonar and onboard :)
    op: you probably mean adi unless you mean onboard ac97 then which yeah a tin can makes a better noise.
  6. Pablo_H
    Pablo_H Member
    Jul 13, 2002
    2,766
    wa
    I'm deciding between two boards for a new system. One has VIA® VT1828S the other has Realtek ALC888 ac97.
    Is either of them remarkably worse that the other?
    PCI slots are at a premium on mobos these days, and my budget can't extend to a decent sound card anyway.
  7. smiddi
    smiddi Member
    Mar 4, 2002
    1,077
    W'gong
    ^ +1 from me
  8. General_Cartman
    General_Cartman Member
    Apr 28, 2005
    2,749
    The Confedaracah!
    The current iMac uses an ALC885.
    OP -> My motherboard with a VIA codec (1708B) has troublesome drivers. In Windows 7, the optical output shuts its self off after 5 minutes for some reason! So frustrating, I have to go back to analogue. So I'd say Realtek, purely for the software.
  9. Comma
    Comma Member
    Mar 19, 2007
    3,682
    OSX also uses Core Audio, which is a vastly superior driver than anything for windows.
  10. General_Cartman
    Apr 28, 2005
    2,749
    The Confedaracah!
    Core Audio isn't a driver, it's an API.
    Mau1wurf1977
    Jul 19, 2006
    13,706
    Country WA
    Thanks for all the input!
    Its odd that Asus puts VIA or ADI sound chips on their entry level boards. Wheras every other mobo company uses Realtek...
    Realtek update their drivers all the time. To be honest I am not sure why they update it so often. What is it they are changing?
    With my current realtek (ALC662 Audio Codec) I have had zero issues under XP, Vista and W7 in games, music, HD whatever...
    Now the Asus board I am looking at uses the VIA codec. So I might just go with Gigabyte simply because I don't want to have issues with the sound and forced to get a dedicated sound card...
    I remember I had a Asus P5B and there where issues with ADI chip in games and I bought a XFi in the end...
    Quality wise I don't care really. I just want something that works and it looks like realtek is the way to go as far as having zero issues.
  12. mtma
    mtma Member
    Aug 12, 2009
    5,839
    I've two ASUS boards with the VIA onboard, and I can say that they're not particularly different in the audio department compared to the realtek chips. I personally haven't had issues with drivers with these chips. I can say however the effects and the equaliser in the drivers are horrible, but you can avoid using them easily.
    I haven't had good experiences with other aspects of these ASUS boards however, but that's for another thread.
  13. Jedi Jezz
    Jedi Jezz Member
    Mar 13, 2003
    938
    NSW 2620
    AFAIK not on vista and win7, all the processing is done via the CPU.
  14. General_Cartman
    Apr 28, 2005
    2,749
    The Confedaracah!
    Newer drives have fixed these problems. VIA and realtek is really much of a muchness, as most of the work these "sound cards" do is done via software.
  15. TRG.dOinK
    TRG.dOinK Member
    Jun 27, 2002
    4,639
    Melb East
    Just choose the most common, Realtek.
  16. foxhole
    foxhole Member
    Dec 31, 2009
    23
    Perth, WA
    Any of the VIA Envy series give cleaner sound than Realtek's offerings, away from that it's probably much of a muchness, either will offload dsp duties to the CPU. Pretty much have to go to one of the endless EMU10k revisions from Creative to get away from that now, but fortunately they have pretty decent sound, Audigy2 and beyond being quite excellent.
  17. Apokalipse
    Apokalipse Member
    May 29, 2006
    4,250
    The sound quality has pretty much fuck all to do with the SPU, and a lot to do with the DAC, and components used in the analogue circuitry as well as the analogue circuitry itself.
    The SPU processes the sound before it's converted to analogue.
  18. phantompisser
    phantompisser Member
    Jul 2, 2001
    977
    Interesting . So by that rational if you are outputting audio over hdmi as unencoded there is absolutely no reason to buy a better sound card . Except for the fact that better soundcards offload some processing off the cpu . How many FPS are we talking in an average game ?
  19. IamDan
    IamDan Member
    May 5, 2009
    591
    Geelong
    Was gonna ask the same thing.. I go digital out, does it just pass it through or is there some trickery involved?
  20. 3Tone
    3Tone (Banned or Deleted)
    Aug 15, 2009
    2,335
    You would be correct. If you're running digital out all the DAC is done by the amp. I'm running the realtek 889 on my mobo via optical to my Integra receiver. Sounds amazing!
