Video Card Crash Help
Discussion in 'Troubleshooting Help' started by bodo, Feb 24, 2017.
  1. bodo
    bodo Member
    Sep 24, 2003
    118
    Hi all, I have a r9 290 that i suspect has been giving me grief of late...
    It just black screens and crashed the system when gaming..
    The temps seem fine and i had some luck with it buy underclocking / undervolting and increasing fan speed...
    I just want to rule out other components b4 buying a new card...
    Do these figures point to anything (i was looking for a temp spike or voltage drop):
    https://dl.dropboxusercontent.com/u/65481500/GPU-Z Sensor Log.xlsx
    any help would be greatly appreciated
    Cheers
  2. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    128,677
    Canadia
    Can you swap in another spare card just be certain?
    Looking like the card is not fearing too well.
  3. warhead
    warhead Member
    Jun 7, 2004
    702
    Looks like it's reading the +12V rail on the PSU a bit low. Down to 11.75v under load and 11.88v idle.
    What PSU do you have?
    bodo
    bodo Member
    Sep 24, 2003
    118
    Cooler Master V850, but at the time of those readings - i think i had teh card 10-12% under voltaged
    Ive just popped a rx 480 in.. will see how it goes in a sec
  5. i7Baby
    i7Baby Member
    Jul 3, 2012
    290
    Maybe you could post the HWInfo 64 Sensors screens.
    And your complete build.
    That'd help.
    bodo
    bodo Member
    Sep 24, 2003
    118
    build is Gigabyte GA-H97-HD3 / 4670k / Kingston HyperX 16 GB / HIS Radeon R9 290 iceQ
    this screenshot is with the 480 that works fine so far :( so looks like its the 290
    Thanks heaps everyone for their time and help!!!!!
  7. alfster
    alfster Member
    Aug 13, 2002
    1,424
    You could give the hair dryer or oven trick a try. I've done the hair dryer trick 3 times on my R9 290, it seems to only work for about 3 months each time though. Turn card over, wrap the card in aluminium foil except for the GPU, then hover a hair dryer over the GPU on high back & forth for about 6 minutes. Allow to cool for 1/2 hour, then re-install in computer, should be ok for another 3 months if like mine.
  8. i7Baby
    i7Baby Member
    Jul 3, 2012
    290
    It'd be handy to see the rest of Sensors eg CPU temps, PSU voltages, etc.
    And know what the rest of your PC is eg PSU.
    bodo
    bodo Member
    Sep 24, 2003
    118
    PSU is a Cooler Master V850... running a rx 480 atm (havnt popped the 290 back in yet)...
    Had soem weird crashes still - where screen wold get "blocky", but had soem errors isntalling drivers - so did teh ususal repairs and clean install of drivers... so far so good
    http://i.imgur.com/4WfR5iu.png
