Virtualbox and XP + ISO
Discussion in 'General Software' started by mixsetup, May 2, 2020.
  1. mixsetup
    mixsetup Member
    Dec 22, 2003
    2,821
    Cairns,QLD
    Hi sorry if this should of been posted somewhere else.
    I have Windows 10 and installed VirtualBox and then installed XP.
    Thing is I need to mount ISO family tree software hence XP.
    I mount the ISO fine using Wincdemu it has to be mounted to use the software as there is a database on it.
    The thing is as soon as I restart XP I have to mount the ISO again.
    When I had a Windows 7 machine XP virtual mode kept the ISO CD drive after I restarted it.
    Can this be done with VirtualBox and the XP?
    Thanks
  2. breech
    breech Member
    Mar 6, 2002
    1,914
    GalaxyWorld
    Vitualbox mounts ISO's natively and they persist ok. Just click the blue CDR icon in the tray to swap ISO's.You shouldn't need to use CD emulation from XP.
    By the way React-OS should be able to handle that application, you should give it a try in another vbox session.
    mixsetup
    mixsetup Member
    Dec 22, 2003
    2,821
    Cairns,QLD
    Thank's for that
    I'll have a look at React-OS now
  4. elvis
    elvis Old school old fool
    41,809
    * Power off the VM
    * Right-click the VM description in VirtualBox Manager, and click "settings:
    * Click "Storage"
    * You'll see "Controller: IDE" with a CD-ROM icon below it. Click the CD-ROM icon.
    * On the right you'll see "Attributes: Optical Drive". Click the CD-ROM icon to the right of that
    * Click "Choose a disk file"
    * Navigate to your selected ISO
    * Once done, click OK all the way out of the menus
    * Power on the VM
    Unless you remove/eject the ISO either via VirtualBox Manger or inside the OS itself, the ISO image will be mounted each time the VM starts form now on.
    mixsetup
    mixsetup Member
    Dec 22, 2003
    2,821
    Cairns,QLD
    Thank's that's what I want is for it to be open each time I start great.
