Vista Ultimate 32bit + Win XP Pro 32bit
Discussion in 'Windows Operating Systems' started by Spamz0r, Aug 23, 2008.
  1. Spamz0r
    Spamz0r (Banned or Deleted)
    Jul 1, 2002
    1,152
    Hi All,
    So I am fairly frustrated with my current setup - gaming performance in Vista 32bit is still poor as.
    I simply want to know if doing a dualboot (as title suggests, one partition on my raid for Vista U 32, the other for XP pro 32)
    Will this work OK ?
    I was thinking Vista is great for sitting on the web, i still like it for officey sort of stuff, but gaming, you just can't beat XP SP3.
    Plus I want to get back into overclocking, even more intense gaming :p and benching, so I NEED XP Pro.
    Edit: Also I was thinking I should install XP onto the first partition - so its the faster parition?
    And do I need to install Vista or XP first?
    Cheers all
    Tom
  2. the scotsman
    the scotsman Member
    Oct 19, 2004
    7,411
    NSW South Coast
    If you're going to do both from scratch, install XP first. The when you install Vista, a boot menu will be created by the Vista install.
    If you want to keep the Vista partition, install XP onto the other partition. You won't have a boot menu, but all you need to do is install VistaBootPro
    This will create a boot menu with Vista and XP when you run it.
  3. ni9ht_5ta1k3r
    ni9ht_5ta1k3r Member
    Feb 11, 2006
    34,928
    地球・オーストラリア・シドニー
    you'll need to repair the vista install after you've installed XP because vista uses a different way to keep the boot information.
    Spamz0r
    Jul 1, 2002
    1,152
    Thanks guys, that's perfect;
    I'll be formatting anyway as i'll have a new motherboard, CPU, video card, etc
    And I think if you switch raid controllers you need to anyway? Maybe not, it doesn't matter the raid 0 array only has one partition and I think a clean slate would be the best starting point :)
    Oh I'm excited now :D can't wait to build this system
  5. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    155,709
    Omicron Persei 8
    I keep a dual boot system going with XP SP3 and Vista 64bit, so that at lans if I ever have a problem with Vista I can always go back to XP. Works really well, and saved my butt a few times : )
  6. bmik
    bmik Member
    Jun 2, 2007
    592
    NW Sydney, NSW
    Just stick with XP?
    I'm a huge Vista fan and if anyone asks I will tell them how much XP sucks compared to it, but I see no justifiable reason to keep Vista and XP on your computer if XP can do everything Vista can do for you plus more. Yes it might be old and yes it is nearing the end of the line but by the time you're almost forced to go to Vista, all those game performance problems will probably be non-existant.
    Think of the HD space being wasted just to have two different OSes. Just because Vista is newer it does not mean it is better for you. I used Win2000 until mid-2005, only problem? I had to keep MSN7 and couldn't go to 7.5. Look at UNIX software: code written in the mid 80's is still being used today.
    I'd recommend you just stick with XP. If you want to dual boot then the easiest way to do it would be to install XP first, and let Vista install its boot manager. You can go edit the startup options in msconfig. It's easier than installing Vista first then editing boot.ini in XP to include Vista in the bootloader list. EDIT: I'd also recommend Vista64 if you are going to be dual booting. May as well prepare for the 64-bit future while you're at it if you have a reliable XP32 to fall back on anyway.
  7. Cozmo
    Cozmo Member
    Jul 7, 2001
    142
    NSW
    can you explain to me why you think xp sucks, i'm interested to know?
    i understand vista has a pretty interface, but apart from this i am interested to know?
    xp should be just as secure as vista as the windows updates are still rolling out and will continue to do so for some time.
    so what are the other reasons?
  8. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    155,709
    Omicron Persei 8
    Wonder if we will see another service pack for XP.....I'm thinking probably not...
  9. bmik
    bmik Member
    Jun 2, 2007
    592
    NW Sydney, NSW
    I don't think XP sucks, I think it's great, but then again Vista is really really great. It was just a way of getting my point across.
    Just off the top of my head two things I really like about Vista that weren't in XP is the prefetching or whatever it's called (the one where you can use USB disks and free RAM to store applications that are likely to be launched) and the fact my disk never seems to be slow or sluggy. Vista seems to defrag as you use it whereas XP never did that AFAIK.
    Spamz0r
    Jul 1, 2002
    1,152
    I think Vista 64bit is the way to go for now >.>
  11. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    155,709
    Omicron Persei 8
    Not considered dual boot scenario?
  12. Boxman
    Boxman Member
    Jul 18, 2005
    1,794
    Victoria
    I agree. Not to turn this into an OS comparison thread but I used to dual and triple boot with Vista x64 and the various incarnations of XP. I no longer feel the need to do that. With Vista x64 SP1 the performance is there, you just need to do your homework and set it up to do what you want it to do. That includes benching and overclocking.
    You won't look back. If you do --> virtualisation.
  13. ni9ht_5ta1k3r
    Feb 11, 2006
    34,928
    地球・オーストラリア・シドニー
    i want to go 64-bit but with the amount of assignments i have for uni I don't think I can afford to have my PC go out of action, even for a few hours.
    Spamz0r
    Jul 1, 2002
    1,152
    Mr Chilled, not anymore
    I really hadn't done too much reading prior to this thread, in terms of xp 64 vs v 64, there really isn't much difference
    I think i'll be happy enough on Vista 64bit even if I am benching.
  15. DraGoN-BoY
    DraGoN-BoY Member
    Nov 7, 2003
    3,002
    Quick question that is a bit off track, I have a Vista 32bit cd key, will it work for 64bit as well?
  16. kreegor
    kreegor Member
    Apr 24, 2007
    5,012
    yes
    10 char
  17. bmik
    bmik Member
    Jun 2, 2007
    592
    NW Sydney, NSW
    OEM? No. Retail? Yes.
  18. the scotsman
    the scotsman Member
    Oct 19, 2004
    7,411
    NSW South Coast
    Not correct. You CAN use the OEM 32-bit key on OEM 64-bit Vista. Some people report it doesn't activate over the net, but activates fine over the phone.
  19. bmik
    bmik Member
    Jun 2, 2007
    592
    NW Sydney, NSW
    It's a dodgy way of doing it though. Sometimes it works but in general OEM keys are for whatever platform they came with. Retail exists so you can put it on whatever you want. The whole point of OEM is to tie the OS to that PC.
  20. eva2000
    eva2000 DDR1/DDR2/DDR3 Addict
    21,902
    Brisbane, Australia
