wall mounting monitor, tilt worth it?
Discussion in 'Video Cards & Monitors' started by havabeer, Oct 25, 2019.
  1. havabeer
    havabeer Member
    Dec 12, 2010
    6,950
    so i have a 32" acer predator monitor that i'm considering wall mounting instead of using the desk stand.
    i'm really wondering if its worth getting a wall mount with a tilt function or if a standard slim flat mount is fine. i assume that if you're seating position is level then you shouldn't really need to tilt the monitor at all.
    any thoughts?
  2. Little Man
    Little Man Member
    Sep 4, 2008
    4,604
    3147
    Tilt allows for error in mounting/multiple people to use it.
    If its not that much more just do it.
    Azzan likes this.
  3. broccoli
    broccoli Member
    Feb 21, 2010
    21,502
    I'd get tilt. Better to have it and find out it isn't needed, than to go for fixed and then find out that you do. Might you want to watch video from a different position to your office chair? You might need to adjust it.
    havabeer
    havabeer Member
    Dec 12, 2010
    6,950
    the only concern i have with the tilt ones is the extra width it adds off the wall. but i think i'll end up with one.
