Water Cooled Fractal Design R4
Discussion in 'Extreme and Water Cooling' started by bobster, Jul 1, 2013.
  1. bobster
    bobster Member
    Nov 11, 2011
    1,027
    Hiya,
    Finalling getting my next watercooling computer on the go:-
    MSI Z87 G45 Gaming
    Intel i5 4670k
    HIS Reference HD7970
    8GB GSkill
    Seasonic 520w PSU
    Fractal Design Define R4
    Sandisk Extreme 240GB
    Seagate 500GB SSHD
    WC gear
    XSPX RX140mm - Fractal 140mm fan
    Koolance HD7970 Block
    Swiftech H220
    EK Compression fittings
    Primochill 3/8-5/8 tubing
    Update 1.8.13
    WC setup changed to reduce internal heat
    XSPX RX140mm + Fractal 140mm fan removed replaced with Noctual 150mm PWM Exhaust Fan
    Swiftech MCR-Q 240 with Enermax 120mm fans
    Photos to come
  2. Kommandant33
    Kommandant33 Member
    Mar 6, 2011
    4,428
    Cheltenham VIC
    What are the plans for this? Are you going to remove the bottom HDD cage?
    bobster
    bobster Member
    Nov 11, 2011
    1,027
    Just finished the rebuild, hdd cage was moved to the middle position to fit the rad, 140mm rad in the rear
    bobster
    bobster Member
    Nov 11, 2011
    1,027
    Started some mild overclocking
    7970 oc to 1ghz
    CPU oc to 4ghz
    After 1 hour of BF3 at max GPU high 40's and CPU high 50's
    Fans no where near max set to 75% is CPU hit 60
    Noticed that the air inside the case was a little warm for my liking so I added an exhaust fan to the side of the case.
    After more gaming noticed temps dropped a degree and noticed the extra fan worked out quite nicely a foot warmer:)
    I still think I need more cold air in the case to assist the cooling of the 140mm exhaust rad
    bobster
    bobster Member
    Nov 11, 2011
    1,027
    System updated as above^^^
    Current OC settingss
    GPU oc to 1.125Ghz
    CPU oc to 4Ghz
    After 1 hour of BF3 at max GPU mid 40's and CPU mid 50's
    It seems like the extra exhaust fans really help with the temps
    bobster
    bobster Member
    Nov 11, 2011
    1,027
    Rebuilt pictures
  7. Kommandant33
    Kommandant33 Member
    Mar 6, 2011
    4,428
    Cheltenham VIC
    Nice work, mate!
    It's a very tight fit - but you managed to do it :thumbup:
    bobster
    bobster Member
    Nov 11, 2011
    1,027
    Thanks Dude,
    Not happy with the tubing atm, need a bay res to tidy the hole lot up
  9. BigDave
    BigDave Member
    Nov 12, 2007
    3,700
    ADELAIDE/5018
    What's your loop order?
  10. HeXa
    HeXa Member
    Jul 7, 2001
    10,211
    Canberra, ACT
    iirc, outlet is top right of the AIO block
    so, CPU->GPU->top rad->front rad->CPU
  11. NinjaStickman
    NinjaStickman Member
    Jul 23, 2012
    285
    Coogee, NSW
    Looks sexy,
    Try some angled fittings for those tubes, you won't go wrong :thumbup:
    Also, from having those very same fans, the lack of air pressure isn't very good for a rad, I swear my air was stagnating unless i had them on mid to high (quite loud) grab some Gentle typhoons or some corsair static pressures when you have the mullah and an upgrade itch.
    bobster
    bobster Member
    Nov 11, 2011
    1,027
    Yup that's the setup
    The Enermax fans are running at 50% pushing air through a low fpi rad, virtually silent and you can feel the air coming through.
    Angled fittings, res and maybe another rad to come, still got a RX120 and EX140 lying around that still can be used or fit a BIG240mm in the front
  13. GhostofDark11
    GhostofDark11 (Banned or Deleted)
    Jun 23, 2013
    26
    Tamworth 2340
    Wow. Nice build :thumbup:
    bobster
    bobster Member
    Nov 11, 2011
    1,027
    R4 is going this week........ New case to come
  15. Reaper_1994
    Reaper_1994 Member
    Mar 24, 2010
    2,044
    Townsville, QLD
    Why? I love my R4 :)
    bobster
    bobster Member
    Nov 11, 2011
    1,027
    Haha cancelled it for now but I cracked the fan mount clip and to but a replacement and a window side panel isn't worth it.
    Waiting for the new case to be released
  17. Reaper_1994
    Reaper_1994 Member
    Mar 24, 2010
    2,044
    Townsville, QLD
    I just ordered the windowed side panel for mine tonight. I've been wanting it for ages but didn't really have the money for it. I personally think it's worth it for sure...
    How much is the fan clip replacement?
    bobster
    bobster Member
    Nov 11, 2011
    1,027
    [​IMG][​IMG]
    Cracked the clip doh
    bobster
    bobster Member
    Nov 11, 2011
    1,027
    Had a day off today and decided to service the computer and rework the water cooling for fun.
    Now only running the H220 kits with Enermax fans, i5 4570k and 7970@1gz
    Silent on idle now and quiet during gaming. Seeing CPU temps hit 63 degrees and GPU hit 55 degrees high after 1 hour battlefield 3.
    Pretty decent AIO water cooling kit tbh.
    I also did a coolant flush and found black particles in the coolant. Swiftech need to do a better job checking these kits before the go out
  20. Reaper_1994
    Reaper_1994 Member
    Mar 24, 2010
    2,044
    Townsville, QLD
    The black stuff could have been from any of the parts... I know some people will flush everything before they go in the loop which I did for my 2 GPU's but others won't. I max at 55 on CPU and 52ish on GPU's.
