water cooled psu progress picture
Discussion in 'Extreme and Water Cooling' started by link1896, Jan 8, 2007.
  1. link1896
    link1896 Member
    Jul 28, 2005
    368
  2. Jeremiah
    Jeremiah (Banned or Deleted)
    Jan 8, 2007
    402
    Clarence Valley
    Duuuuuuuuuuude! :Paranoid:
  3. kr0nic
    kr0nic Member
    Oct 18, 2006
    983
    Newcastle
    id have all 3 emergency services on standby when u fire it up for the first time!
  4. phextwin
    phextwin Member
    Aug 30, 2003
    4,221
    Geelong Velocity:Unknown
    That's just tremendous :thumbup:
  5. OhFoRkMe
    OhFoRkMe Member
    Apr 27, 2005
    3,429
    Joyner 4500
  6. sevenAU
    sevenAU Member
    Dec 17, 2006
    511
    South Australia
    That looks fairly dangerous... :shock:
  7. DavLe.BeRRy
    DavLe.BeRRy Member
    Jun 11, 2006
    1,989
    Perth, WA
    This shall be an interesting outcome indeed
  8. ener
    ener Member
    Dec 23, 2005
    3,620
    Gold Coast
    oh its a psu, i thought it was two video cards lol :tongue:
  9. Philbee
    Philbee Member
    Dec 21, 2006
    345
    holy crap, thats awesome
    just like in the old science fiction movies ;)
  10. Rmatin04
    Rmatin04 Member
    Jun 23, 2004
    1,061
    How exactly is it supposed to work? The contact area for the water seems to be very small compared to the aread you're trying to cool.
  11. Kiba
    Kiba RIP Lest we forget!
    Jun 21, 2006
    685
    Nadi Ali, Helmand
    divided by zero ??? OH SHI-!!!!
    edit my also want to ask a mod to change the thread name. water cooled "PUS" sounds like your conducting medical experiments :Paranoid: ...your not right ... RIGHT !?!?!
  12. Long Haired Git
    Long Haired Git Member
    Jul 26, 2001
    2,667
    Hornsby, Sydney
    How much to make me one?
  13. AussieJester
    AussieJester Member
    Jul 12, 2004
    2,552
    Perth Western Australia
    LOL LHG sees the potential hehehe
    Nice job mate seen a few PSU watercooled over the years non as neat as yours top effort...
  14. slamaa
    slamaa Member
    Jun 1, 2006
    2,064
    Reservoir, VIC
    Man that is awsome.... their wont be problem unless ther is a leak in that exact area of the loop. and id say theres no chance of that.
    nice work mate
  15. iCrunk
    iCrunk Member
    Apr 17, 2006
    702
    Melb SE
    Will there be an inbuilt radiator+pump in the psu case? :)
  16. slamaa
    slamaa Member
    Jun 1, 2006
    2,064
    Reservoir, VIC
    lmaooo, why would you inbuild a pump and rad, too small????
    you woulld problii have it on a seperate loop or on a previouys loop.
    link1896
    link1896 Member
    Jul 28, 2005
    368
    water cooled pus, haha, the fun of typos when tired. where do I start?
    first of all I play with silly stuff like electricity and water at work, so there is minimal danger for me, but because this is the internet, "I saw it on the internet" isn't enough training/experience. Mains electricity has a good chance of killing you if you are stupid or careless.
    Don't attempt this if you are not sure what you are doing.
    dangerous? dangerous is a 10,000 watt 50 volt 200 amp power supply that will do 2000 amps into a dead short until you trip breakers, coupled to a 50kV igniter circuit too.They are xenon lamp power supplies. The things that give film projectors their light. Nothing like fixing one at midnight or first thing Monday morning. I've watched 500kV arc 3-4 feet through the air and strike someone on the arm, even better, "I told you so" hahahaha
    To the creation. The pipe, which is 12mm water pipe, I machined in the mill into a C section, the water actually makes contact with the plate. Its a tight fit over the plate, so there isn't a solder layer between the copper plate and water.
    As to heat, I assumed a worst case, 500w psu, lets say it has 70% efficiency (its an 80plus psu though!)
    thats 150 watts of heat worst case scenario, with every hot part bolted to water cooled copper, including the main transformers frame, I'm expecting nothing to get hot, let alone past the point of safe operating temp. I've cooled power amplifier transistors with a similar cold plate arrangement and they ran cold. My old concerns at all are the output inductors.
    As to selling, if this works as well as I'm hoping, I think I could make them for less then a pacific island's debt, enough to interest a few. time will tell.
    as far as leaks go, sure a leak will be catastrophic, but so far i've tested to 80-90psi with no signs of a leak.
    as to what loops/rad/pump, see my sig for "rad". HTPC might share this radiator, or i might do another, not sure yet, got a pile of old ac condensers and evaporators. Planning to put one part of a small one inside the box with two yate loons to keep the box air temp down, box will be 100% sealed to help silence.
    I'll post pics as we progress, got a few more to add now of different angles.
  18. littlee
    littlee Member
    2,027
    Crazed Knife Stabbing Central
    nice work.
    I rarely post in here anymore. Too much off the shelf crap and not enough home brew.
    link1896
    link1896 Member
    Jul 28, 2005
    368
    thanks dude, been meaning to add ur plex top block with nothing but a drill and dremel is quite an achievement
    link1896
    link1896 Member
    Jul 28, 2005
    368
    yep, with no water cooled psu's it was my only solution. there were stories for a while that zalman was going to release a water cooled psu, but it never happened, and then 8 months later they released a heat pipe cooled one that is ho hum.
