Watercooling Collective Sticky
Discussion in 'Extreme and Water Cooling' started by zeropluszero, Aug 14, 2010.
  1. scotteee
    scotteee Member
    Apr 23, 2007
    2,511
    Cant find any Ek H30's in Aust, so diff tubing is the go?
  2. walker_2003
    walker_2003 Member
    Jan 15, 2003
    8,770
  3. scotteee
    scotteee Member
    Apr 23, 2007
    2,511
  4. Tangence
    Tangence Member
    Feb 24, 2012
    59
    Mill Park, 3082
    www.gammods.com.au sell them. None in stock until the 6th is all.
    www.pccasegear.com sell them as well.
    ( It's and O as in Octopus not a zero :D )
  5. scotteee
    scotteee Member
    Apr 23, 2007
    2,511
  6. Tangence
    Tangence Member
    Feb 24, 2012
    59
    Mill Park, 3082
  7. walker_2003
    walker_2003 Member
    Jan 15, 2003
    8,770
    yup if its just cpu stock pump will be fine, tho sometimes a lil noisy!
  8. scotteee
    scotteee Member
    Apr 23, 2007
    2,511
    Ok so now im torn between waiting for the EK h3o or buying the XPCS kit right now? hmmmmmmmmm
  9. Tangence
    Tangence Member
    Feb 24, 2012
    59
    Mill Park, 3082
    Knowing this industry, by the time the kit is available at gammods a better kit will be the same price but will no be arriving until the week after.
  10. scotteee
    scotteee Member
    Apr 23, 2007
    2,511
    I'm trying to decide between the 2, one is $140-150 cheaper than the other, but cant seem to find any proper reviews on the EK h3o, it does look the goods!
  11. Scottymag
    Scottymag Member
    Oct 28, 2009
    169
    rockingham
    DO A REAL LOOP!
  12. scotteee
    scotteee Member
    Apr 23, 2007
    2,511
    Scotty dont even talk to me until you go phase cooling, until then you cant lecture me ;)
  13. Scottymag
    Scottymag Member
    Oct 28, 2009
    169
    rockingham
    would if i had spare moneys :( + basic watercooling loop maxes out a 2700k anyway hahaha
  14. Tangence
    Tangence Member
    Feb 24, 2012
    59
    Mill Park, 3082
    Would it affect a loop much if I were to use right angle joints all over the shop instead of slight bends?
    My plan is this: (you'll have to use your imagination in regard to the Z-axis)
    It uses a Koolance RP-452X2 res and 2 PMP-450S pumps to give you an idea of where the tubing runs in respect to the z-axis. (loop 2 is on the pump closest to the open panel in the diagram)
    I don't really want to use angle fittings between the cpu and mobo blocks but everywhere else i want the tubing to go in a straight line.
    Cheers,
  15. Hive
    Hive Member
    Jul 8, 2010
    4,706
    ( ͡° ͜ʖ ͡°)
    Judging from that pic you are going push/pull....
    Push pull for that many fans is a fucking huge waste of money for a 2-5% increase in cooling power.
  16. Tangence
    Tangence Member
    Feb 24, 2012
    59
    Mill Park, 3082
    I have the money. So i figured why the hell not.
    I only plan on doing push fans on the internal 420 rad
  17. plzdontbetaken
    plzdontbetaken (Banned or Deleted)
    Jun 27, 2011
    240
    large amount of wealth and your using that fugly case.....
  18. Tangence
    Tangence Member
    Feb 24, 2012
    59
    Mill Park, 3082
    Hello Mr. insensitive.
    Well I think it's beautiful.
  19. Creekin
    Creekin (Taking a Break)
    Jun 21, 2003
    10,109
    nope, it takes about 30 hard 90 fittings to raise the cpu temp 1deg.
    http://martinsliquidlab.org/2011/01/30/fittings-and-elbow-impacts/
    its more like 20% but still a huge waste of money, space and eardrums imho
    http://www.coolingtechnique.com/mar...an-Orientation-And-Shroud-Testing-Review.html
    ignore copie..hes just a grumpy old man :rolleyes:
    you should probably start your own thread asking for advice on ur build..
    but why go for something so big and complicated for ur first loop?
    KISS
  20. Tangence
    Tangence Member
    Feb 24, 2012
    59
    Mill Park, 3082
    Excellent!
    Doesn't matter. Had fans.
    Iunno....
