Watercooling, finally.
Discussion in 'Extreme and Water Cooling' started by Huggy_Bear64, Sep 22, 2011.
  1. Brianf1971
    Brianf1971 Member
    Jun 22, 2012
    590
    Perth WA
    The only Tube that looks out of place is Res to Pump top, but not that bad, it's hard to tell from pics but have you thought of using
    http://www.thekoolroom.com/product/bitspower-g14-carbon-black-triple-rotary-90-degree-g14-extender/
    Plus
    http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_160_300_1402&products_id=20340 or longer to connect the two ?
    The other option is turn the pump on it's end and use http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_160_300_1402&products_id=20339
    to connect the two
    As I said hard to tell from the pics the clearances and how things line up, also with the second option you would need to re-tube the pump outlet or use a 90 which you said you didn't like.
    Brian
    Huggy_Bear64
    Huggy_Bear64 Member
    Apr 24, 2010
    3,096
    Melbourne, VIC, 3127
  3. munchkin1
    munchkin1 Member
    Jun 6, 2010
    4,565
    cool build log bro
    Huggy_Bear64
    Huggy_Bear64 Member
    Apr 24, 2010
    3,096
    yeah man.
    Too poor for the next stage, but I've got big plans to downsize to mATX with a nice Max V Gene and some HD7970s :thumbup:
    Going to need external rad though, which could get annoying :Paranoid:
  5. munchkin1
    munchkin1 Member
    Jun 6, 2010
    4,565
    mATX is for noobs lol and amd cards are also for noobs if going crossfire :p
    Huggy_Bear64
    Huggy_Bear64 Member
    Apr 24, 2010
    3,096
    Better than fucking nvidia.
    WTF dual slot cards. Eww. :sick:
    Edit: Full size mobos are for noobs.
    What would you need to waste all that space on?
    I can fit crossfire GPUs, a soundcard, an overclocked CPU and a bunch of HDDs in a mATX case. Why would I bother with a big, ugly full size thing? :confused:
  7. aeries
    aeries Member
    Dec 5, 2011
    1,370
    i smell a fight.
    mATX :thumbup:
    Red team :thumbdn: until 8k series comes out, if its what it looks like on paper then :thumbup:
  8. xRdawGz
    xRdawGz Member
    Dec 16, 2007
    760
    wait till you see my matx buildlog, coming soon ;)
  9. munchkin1
    munchkin1 Member
    Jun 6, 2010
    4,565
    Haha my mATX comment was just trolling but I'm serious about AMD cards for dual card Setups. Some of the frame dropping/cheating articles even with 7970s on current drivers are just downright scary.
    I am keen to see what 8000 series brings though
  10. aeries
    aeries Member
    Dec 5, 2011
    1,370
    on paper it's supposedly the 780 but at half the price
  11. BigDave
    BigDave Member
    Nov 12, 2007
    3,705
    ADELAIDE/5018
    not really :D This is my server :p
    if you want some more links to some other (M-ATX) TJ08-E builds let me know.
    Huggy_Bear64
    Huggy_Bear64 Member
    Apr 24, 2010
    3,096
    OK so it's only been three years, but my loop finally gave up, popped a tube, and pissed water all down the inside of my case.
    Through some incredible fluke, nothing expensive got soaked, so I just had to dismantle the loop and retube it, but I also took the liberty of cleaning everything and finding a better way to mount the pump.
    After scrubbing weird white goop from inside all of the waterblocks I think I had a plasticiser problem as well, so all new tubing was required with primochill stuff (that doesn't even come in UV purple :upset: ).
    It turns out 90 degree rotary fittings start to leak after 5ish years, which explains the big loops of tubing in the middle.
    I am a huge fan of the new pump placement in almost all respects, but bleeding an upside down pump is the fucking worst; it took like 3 solid hours of fucking with it until I realised I had to take it out, turn it right way up, bleed the loop, then screw it back in up top. :tired:
    PS black on black is super hard to photograph with a phone camera through a case window, sorry about the image quality.
