Waves Audio Content Creator Toolkit
Discussion in 'Live Streaming & Content Creation' started by super kermit, Sep 23, 2020.
  1. super kermit
    super kermit Member
    Jun 18, 2002
    1,327
    Sydney Lane Cove 2066
  2. Boneman
    Boneman Member
    Apr 6, 2003
    6,736
    Tokyo
    I would want a seperate EQ for surgical stuff and Compressor, or some kind of channel strip.
    Are you using a DAW as a host? If so your stock plugins will already work.
    For just voice-over type work and not singing a combo of either of these will work.
    EQs -
    Q10
    Renaissance EQ
    F6 Dynamic
    Comps -
    Renaissance Comp
    DBX 160
    Channel Strips -
    Scheps Omni channel
    Renaissance Channel
    SSL channel strips
    super kermit
    super kermit Member
    Jun 18, 2002
    1,327
    Is that from the waves site?
    Sorry, what od you mean by DAW as a host?
  4. Boneman
    Boneman Member
    Apr 6, 2003
    6,736
    Tokyo
    Yes all Waves plugs.
    What software will you use to run the plugins?
    super kermit
    super kermit Member
    Jun 18, 2002
    1,327
  6. Boneman
    Boneman Member
    Apr 6, 2003
    6,736
    Tokyo
    I see, Ableton is a DAW itself, so it will have its own EQs/Comps etc., so you can do everything with it already.
    Probably not gonna make much difference which plug-ins you choose for free, as you might end up using different ones in the future so no stress, just get what you think you want.
    Once you start messing around with audio you will develop your own workflow anyways and go down the rabbit hole of VSTs.
    If you prefer a subscription based plug-in service check out Plugin Alliance, killer stuff.
