weird display artifacts = CPU dying?
Discussion in 'Troubleshooting Help' started by crepuscular, Jun 26, 2020.
  1. crepuscular
    crepuscular Member
    Jan 19, 2009
    318
    Sydney OR Osaka, Japan
    Hey guys, but I'm bit stumped by the symptoms, never have I been so confused in my years of building and troubleshooting PCs with the symptoms that I'm seeing.
    The initial symptom of something with my rig is as I was playing Guild Wars (yeah, a very old school game), the game suddenly crashed and it just kept on crashing with "Assertion: val >= -0.5f", so I have a feeling there could be something wrong with my RAM, but both Microsoft MDT and MemTest86 came back clean. :confused:
    Chat to their support team, they said maybe the game file is corrupted, tried to reinstall the game, but even the installer is crashing with the same error. So I reinstall Windows 10, no luck; yesterday bought a brand new SSD (cause it was on special) and reinstalled Windows, new SATA cable, still no luck.
    That definitely ruled out SSD being an issue.
    Then about, maybe a week later, I started to notice Youtube videos are starting to display these weird tiny artifacts on Firefox.
    To rule out this is not a driver issue with Nvida's latest driver, so I reverted back to a driver that's about 6 months old, the artifacts persisted.
    To rule out isn't a GPU issue, I switch it out to my old 780, but the same issue persisted.
    Tried a different PCI-E slot, no luck.
    There a visible deterioration of the fault, the artifacts getting worse day by day, it went from random tiny pixels to giant patches.
    The same video is fine in Chrome, task manager shows there GPU activity on Chrome but not firefox, so I'm guessing Firefox is using software rendering instead of hardware acceleration(?)
    Now that makes me worried, that my CPU is possibly dying (?)
    The night before, I decided to upgrade my Nvidia driver, because I was left with an old driver from previous troubleshooting. Now this is where I noticed there could be something very wrong with my CPU (?), the installer would start and just disappear. Looking at task manager, I can see the installer process is still running, but visibly it is as if the process had crashed, it's not coming up as a task with ALT+TAB.
    Tried running Intel's CPU DT, it came back clean though.
    So I'm at lost what component is failing, because all the diagnostic tools came back clean
    Don't want to run out and spend couple hundred, or maybe thousands at the current difficult time, and end up the component(s) is ok
  2. power
    63,175
    sounds like ram/gpu maybe even psu.
    i'd let memtest run overnight, sometimes a single pass isn't enough, be sure to select all tests not just the quickies.
  3. daehenoc
    daehenoc Member
    Nov 4, 2005
    2,568
    Mt Gravatt E, BNE, QLD
    It's probably not the CPU, but your GPU. Screen artifacts indicated something wrong with your video card - try swapping it out for another, or if you have onboard video, take our your dedicated video card and see if the on-board video still does the artifacts.
    Damn, power beat me to it!
  4. daehenoc
    daehenoc Member
    Nov 4, 2005
    2,568
    Nothing wrong with a quickie, but yeah, doing the full test and doing multiple runs of your memory should pick up any memory errors. (I'm usually happy with running memory tests 3-4 times, unless I think it's a very intermittent RAM fault...)
  5. power
    63,175
    plenty wrong with the quick tests - if you fail a quick test this is usually just a confirmation to you, also multiple passes will also heat the memory up nicely. overnight is easy because, well you are asleep!
  6. Matthew kane
    Matthew kane Member
    Jan 27, 2014
    2,709
    Usually quick tests only test the first and last couple hundred/thousand blocks of data not the entire thing. Artefacting can be a result of a faulty gpu, faulty gpu vram, faulty RAM, or bad system driver files.
    crepuscular
    crepuscular Member
    Jan 19, 2009
    318
    Thanks for the replies :)
    Yeap, already tried swapping, same behavior on both 1080Ti and 780Ti cards
    graphic in my BIOS already set to PCIE instead of Auto; tried swapping to a different PCI-E slots, no luck
    Here's what I was talking about the artifacts on Firefox, but not on Chrome.
    Plus, I don't think GPU would cause distortions like this, would it (?)
    FYI, the game runs fine once I get pass the login screen, no artifacts at all at high settings, hence I do not believe it's a GPU issue ;)
    I've let it run overnight again, still came back clean
    Because I'm running 4 channels sticks, I have tried to pull pairs of them out and run just one 2 channels to see if it is cause by a faulty stick, but no luck
  8. power
    63,175
    that so looks like GPU. The only other thing that could do it is a driver but yeah..
    Being that it's doing it on more than one GPU - a fresh install on a spare HDD for testing would be ideal here.
  9. daehenoc
    daehenoc Member
    Nov 4, 2005
    2,568
    Goddamit, beaten :p That's what I was going to say, do a fresh clean install of Windows on a spare drive, new clean drivers and see if the problem persists. If it does persist, it's either both your video cards are faulty (unlikely, but possible), or that particular driver version has a problem with the specific BIOS version of your motherboard, and causes artifacts, and no-one has bothered to complain to MS or the manufacturer that there is a problem, so they haven't fixed it. Also highly unlikely, but I have seen things like this happen!
  10. FOTW
    FOTW Member
    Jul 20, 2002
    1,080
    Kilcock, Ireland
  11. de_overfiend
    de_overfiend Member
    Jul 12, 2001
    2,398
    Gold Coast
    my vote is for backup/format/fresh install
    that will rule out any software problems - ram is clearly fine and it is doubtful that it would happen with 2 different video cards
    crepuscular
    crepuscular Member
    Jan 19, 2009
    318
    yeah, it's a fresh install, a second time, this time on a brand new ssd
    100% not the RAM, I just got new ones today and I put them on, still reproducing the issue.
    GOD!!! why i skimmed your comment?! thought you said to disable the i-gpu, i happened to try the exact thing you asked me to try!!! pulled out the 1080 and run on i-gpu.
    and YEAP!!! still having these distorted GUIs with certain programs on i-GPU.
    So I'm guessing my hunch was right, that the CPU is busted(?) it's the only component, and the motherboard, that had stayed constant through all these troubleshoot
  13. mr camouflage
    mr camouflage Member
    May 25, 2012
    973
  14. power
    63,175
    OP mentioned it also happened in a game.
    GPU seems to be ruled out, from here it's board or chip. OP should test with as few components as possible to replicate fault.
  15. daehenoc
    daehenoc Member
    Nov 4, 2005
    2,568
    Probably not the CPU, but something hinky on the motherboard, e.g. with the PCI-E bus. If you've eliminated everything else, yeah, it looks like you're going to be getting new motherboard and CPU!
