Weird issue booting
Discussion in 'Troubleshooting Help' started by VirtualNinja, Sep 13, 2017.
  1. VirtualNinja
    VirtualNinja Member
    Apr 27, 2003
    889
    North Parramatta
    Hey guys looking for some input.
    I went to boot my PC this morning, no go Asus Qled showing a A2 error.
    System 1
    Asus z68 Deluxe
    i7 2600k
    16Gb (4x4) 2133 CL9 G.skill DDR3
    MSi 980ti
    XFX Black ed 750w PSU
    2x 500gb 840 evo
    3x HDD
    So I checked cmos battery, 3.3v so that's ok. I pulled the GPU and put it in a Phenom x6 system and that booted fine.
    Gutted the entire case and set it up on a outside the system. the problem persisted. I decided a motherboard swap, I have a spare identical board with a i52400 in it. So I swapped the CPU's and booted the 2600k and new board, same issue. Switched to the 2400 & the old board, the same issue.
    Decided to dig out a old GTX770 it booted, powered down replaced the 980ti and now it boots. I did the same GPU swapping method with 2400 system exactly the same results it finally booted after the 770 was put in the system.
    Do you think the PSU is on it's way out?
    Don't have a spare sitting around and not keen on gutting the Phenom rig.
  2. Bold Eagle
    Bold Eagle Member
    Jun 28, 2008
    6,714
    From the mobo Q Codes it is noted that is an:
    http://www.cizgi.com.tr/upload/pms_dosya/245/p8z68_deluxe_en.pdf
    A2 IDE Detect
    You have 2 SSD and 3 HDD. Can you define how they are configured (RAID?, etc).
    It is also noted in the mobo manual it has 4xSATA3@6.0Gb/s (2 are Marvel) and 4xSATA2@3.0Gb/s ports.
    What is your OS on? Can you swap out the SATA cable/s for it and see if the issue recurs.
    Here is a meaningful comment for that error:
    http://www.tomshardware.com/answers/id-2261374/asus-hero-motherboard-error-code.html
    Considering you have 5 drives connected one of these could be causing an issue during boot.
    VirtualNinja
    VirtualNinja Member
    Apr 27, 2003
    889
    North Parramatta
    Thanks for the input.
    No raid setup, the 2 SSD's are on the Intel 6.0Gb/s the remaining 3 drives are on the Intel 3.0Gb/s ports.
    I did try the boot drive only with a new sata cable and that presented no difference.
  4. Bold Eagle
    Bold Eagle Member
    Jun 28, 2008
    6,714
    Error still occurring?
  5. terrastrife
    terrastrife Member
    Jun 2, 2006
    18,207
    ADL/SA The Monopoly State
    Get it stable and try reflashing the firmware.
    VirtualNinja
    VirtualNinja Member
    Apr 27, 2003
    889
    North Parramatta
    It still happens occasionally, motherboard is on the latest bios, SSD's are on the current firmware. Today unplugged the HDD's it booted, reconnected the HDD's it booted.
    Ah I think I have found the issue, checking drives in crystal disk is throwing up a caution on reallocated sector count. New HDD ordered. Well see how it goes.
