Welders for noobs
Discussion in 'Hobby Engineering' started by Archades, Apr 18, 2011.
  1. 1shot1kill
    1shot1kill Member
    Jun 3, 2003
    8,962
    Where the wild things are
    RussellK did none of that. A lack of basic reading comprehension seems to be the issue here.
  2. RussellK
    RussellK Member
    Jun 11, 2003
    511
    If you have that experience with welding, then you should be able to recognise the profile and symmetry of a fillet weld. The soot out from the base of the weld is clearly sitting on flat plate, not on weld material, and looks nothing like the slag you get on a stick weld.
    That said, a lot of people who only MIG weld don't have the eye for a good weld, as a MIG will put down a nice-looking bead regardless of whether the joint prep and speed/volt controls were correctly set for good penetration and strength. There's good reason why expert welders regard MIG as a "metal squirt gun".
  3. Mathuisella
    Mathuisella Member
    Dec 3, 2002
    7,540
    in your gearbox...grindin
    Quoted for truth. I've stuck with Arc for all my weld except for a couple when i borrowed a mate's mig when i was out of rods. The mig felt weird, yet provided an ok weld.
    I want to get into tig for more intricute work though.
  4. mils1
    mils1 Member
    Jul 17, 2005
    1,028
    Speed is the key when production requires it. Twin Pulse MIG machines with real time synergic computers are far from squirt guns. I have owned a Fabrication shop for nearly 9 years, I am certified in Pressure Vessel Welding for TIG MIG & Stick, I have done welding for 15 years, first 4 years was 99.99% Stainless steel, purge welding food grade tube & fittings etc
    Cheap machines = coarse adjustments, i.e 40-50-60-70 amp adjustments
    Expensive machines = really fine adjustments, i.e 40-41-42-43-44 & real time voltage regulation etc.
    Advice when buying a welding machine is don't buy unless it has at least 3 years warranty
    Archades
    Archades Member
    Oct 26, 2005
    1,960
    Jeebus Land
    Thankyou:D
    What are those twin pulse mig jobbies worth just outa curiosity, and whats the most expensive form of welding?
  6. mils1
    mils1 Member
    Jul 17, 2005
    1,028
  7. bl4ck32
    bl4ck32 Member
    Aug 3, 2005
    4,522
    local
    Depends on the welder size, as they range. When i was looking a little while ago the entry level commercial ones I used for work started at around 2.5K.
    TIG welding titanium would be expensive, but TIG itself isnt the most expensive. Expense comes down to material, and consumables used.
    Also, lol at some of the keyboard welders. Appears only a few have worked in the industry who gave advice.
    Archades
    Archades Member
    Oct 26, 2005
    1,960
    Jeebus Land
    Sounds like an expensive hobby:p But I spose you buy a decent one and it lasts 20-40 years?
    Lots of experts in here:p I'm just happy to see the cheapie does alright.
  9. Ch4iS
    Ch4iS Member
    Jul 2, 2008
    828
    swsyd
    Wona list the price of those Synergic machines also? They are far from cheap, going into 5 figures last I remember.
  10. mils1
    mils1 Member
    Jul 17, 2005
    1,028
    18k each, not cheap at all
  11. RussellK
    RussellK Member
    Jun 11, 2003
    511
    At that price I'd expect the machine to be doing the welding for you.
  12. Betzie
    Betzie Member
    Aug 17, 2004
    774
    Just snagged a little mig today, $850 on special
    http://www.unimig.com.au/catalogue_product.asp?product=32&category=1&subcategory=2
    In all honesty I wouldnt buy anything less powerfull or cheaper than this machine.
    Back in the day before inverters were common the SiP Coppermate and the WIA machines were the pick of the compact models, BOC sells a decent compact machine the MAGMATE 180 but I like the torch that comes with the UNI Mig
  13. mils1
    mils1 Member
    Jul 17, 2005
    1,028
    Titanium needs to be induction heated & welded in a 100% oxygen free environment.
  14. RussellK
    RussellK Member
    Jun 11, 2003
    511
    That's an excellent price - I paid about that for the previous model in the 165A size. I like the addition of digital displays and the spool gun connection on the new model.
    As for the "I wouldn't buy anything smaller", can I ask what it is people actually weld? In addition to the MIG, a lot of the time I use a BOC Smootharc 130 inverter slung over my shoulder.
    With a 3.2mm stick on about 110 amps, it does sections up to 4-5mm no problem, above that a root gap or bevel and multiple passes does the job fine. Are people routinely welding 8mm+ sections with their 200A welders or am I missing something?
  15. Betzie
    Betzie Member
    Aug 17, 2004
    774
    I'm a fitter and turner, not a welder so I'm not challenging what you have said but I was under the understanding it can be done without a sealed chamber. I have seen someone weld it in a special gas bath in his welding cell.
    Most interesting type of welding I have seen is tripple head sub arc, the transformers are huge to run 24/7
    Refurbing rope sheaves and rope drums for dragline excavators used up to $120,000 worth of wire which I promply machined most of it off :)
  16. Betzie
    Betzie Member
    Aug 17, 2004
    774
    Its for a small workshop, not my home garage, but when welding 6-8mm and if you want to do alloy or stainless it pays to have a bit of head room.
    Being a fitter I do not weld every day but when I need to it usually means it has some structural or strength requirement and when I weld it I want it to stay welded :)
    130 inverter MMA/TIG are great general purpose but I find them a bit small to TIG effectivly
  17. mils1
    mils1 Member
    Jul 17, 2005
    1,028
    I'm a fitter & machinist by trade aswell, that is the way i TIG weld titanium tube (purged)
  18. TERRA Operative
    TERRA Operative Member
    Jul 8, 2005
    6,925
    Niraikanai
    Just got myself a free inverter TIG. It's a rubbish current model Chinese made BOC Smootharc TIG 185 unit, but it'll do the job (HF start, yay!) especially seeing as I can get spare parts practically free.
    I already got an older 250A single phase Kemppi/BOC MIG machine and a few cheap and nasty Weldstar 150 stick welders to make one good out of the two (I might populate the board with the extra MOSFET to increase reliability, those Chinese units run the components on the ragged edge of their ratings), so all I need now is a plasma cutter and I'm set. :D
  19. 2xCPU
    2xCPU Member
    Jan 21, 2005
    3,328
    Saigon
    Why are you being such a dick?
    My post was after you'd explained there was no slag, but everyone was still ripping into IntelInside.
    I simple looked at your photo and thought that it was not surprising that someone mistook the soot for slag - suddenly it's all my fault.
    2.
  20. Mathuisella
    Mathuisella Member
    Dec 3, 2002
    7,540
    yummy plasma cutters mmm.....
    so many times one would've been handy to have.
    awkward areas to cut and the only alternative at hand is a chunky angle grinder :(
