What are typical radiator temperature tolerances?
Discussion in 'Extreme and Water Cooling' started by Reaper, Feb 19, 2019.
  1. Reaper
    Reaper Member
    11,240
    Brisbane, Qld, Australia
    Looking at a Thermaltake Pacific RL140, what should it be able to handle? Thinking of a project where it's the right sized radiator to add to a vehicle loop that sees a typical ~90c operating range. Going for a sub loop off the main one. Thanks.
  2. juzz86
    juzz86 Member
    Nov 15, 2013
    976
    Forth, TAS
    Most brand-name PC-grade watercooling gear is rated to 60C.
    That probably applies to plate, tubing, Acetal and Delrin more than anything, but no guarantees at 90C :thumbup:
    Reaper
    Reaper Member
    11,240
    Ok, thanks for that. I'll have to look at something else then. It's just that cooler was a perfect size.
  4. juzz86
    juzz86 Member
    Nov 15, 2013
    976
    Forth, TAS
    Newer automotive gear is mostly alloy - eBay has heaps of cheap Aluminium radiators for peanuts - won't hurt the wallet as much if it doesn't stand up to the punishment :thumbup:
  5. javascripterror
    javascripterror Member
    Mar 8, 2002
    3,169
    NSW
    Ju
    Just watch out for mixed metals in the loop.........would need to use a corrosion inhibitor or the aluminium will turn to goop
    juzz86 likes this.
