What consumes less power?
Discussion in 'Overclocking & Hardware' started by neK, Apr 10, 2009.
  1. neK
    neK Member
    Feb 3, 2005
    2,910
    Ive got a few machines at home and im wondering which one would be best left on 24/7 to use as a torrent machine/media server.
    Machine #1
    Dell GX270 SFF PC
    P4 3.0Ghz (Prescott) with 1Gb ram and onboard video (865G chipset).
    160Gb Hdd
    160w PSU
    (As there is not enough room on this PC, ill also be connecting an external 400Gb 3.5" hdd to it).
    I could put the 400Gb instead the PC, however i figured it would be handy to have it as an external incase i needed to take it somewhere).
    Machine #2
    E8300 + Gigabyte EP31-DS3L + 2Gb Ram + 7600GT
    WD 500Gb (AAKS) hdd + Seagate 320Gb hdd
    Enermax noisetaker 430w PSU.
  2. Shinanigans
    Shinanigans Member
    Apr 7, 2006
    4,833
    Central Coast
    I would guess the Dell, easily.
  3. Kelvin
    Kelvin Member
    Jul 1, 2001
    2,897
    Melbourne 3103
    I would have the E8300 consumes less easily...
    The Presshots consumes lots of power ++++ 95nm process.
    the E8300 is a 45nm process..
    but offest by the 7600GT in the E8300...and thee xtra hard disk..
    I could be very close.. however.. I still would have though the E8300, probably consumes less...
  4. flinchy
    flinchy Member
    Jan 18, 2007
    6,375
    Northlakes
    processors from one generation to the next dont really consume and more or less power.
    intel has the whole 1:1 power increase to performance gain policy
    each die shrink reduces power in a generation. each generation increases power+performance
    die shrink reduces power.
    etc.
    7600GT would be the biggest difference
    so Dell. definitely.
  5. Shinanigans
    Shinanigans Member
    Apr 7, 2006
    4,833
    Central Coast
    neK
    neK Member
    Feb 3, 2005
    2,910
    But definitely a PSU with an output of 160w (Dell) should consume less electricity than a Pc running on a 430w PSU (E8300 PC) right?
    That said, everything seems to be pointing to the dell already.
  7. flinchy
    flinchy Member
    Jan 18, 2007
    6,375
    Northlakes
  8. Dezza Bot
    Dezza Bot Member
    Aug 16, 2004
    4,613
    Central Coast, NSW
    There will be efficiency curves for each PSU so I wouldn't make that conclusion just yet. Probably eaiest just to put both on a meter and find out for sure. Make sure all the power saving features of the Gigabyte EP mobo and 8300 CPU are on, but even if they are the videocard is probably going to use up a fair bit just by itself.
  9. DeejW
    DeejW Member
    May 18, 2008
    1,951
    Margaret River WA
    I would say the Dell would pull about 180w. the other would pull about 200-220w, pretty negligible difference between the two.
  10. Shinanigans
    Shinanigans Member
    Apr 7, 2006
    4,833
    Central Coast
    You know what i meant. :tongue:
    A 430w PSU won't pull 430w unless it's 100% loaded. The Dell may have a 160w PSU in it, but it's probably loaded to 80-100% (bad). Whereas the E8300 machine may have a 430w PSU in it, but it's only loaded to 40%.
  11. Butcher9_9
    Butcher9_9 Member
    Aug 5, 2006
    2,599
    Perth , St James
    PSUs are most efficient when running at about 80%
    40% load on the 430w would most likely alot of power to the overall consumption
  12. Shinanigans
    Shinanigans Member
    Apr 7, 2006
    4,833
    Central Coast
    Sure, but you're talking about maybe a 5% variance in efficiency... at <200w.... it's not going to equate to anything measureable.
  13. Dezza Bot
    Dezza Bot Member
    Aug 16, 2004
    4,613
    Central Coast, NSW
    You're also assuming the psu in the Dell is of a decent quality....
  14. Butcher9_9
    Butcher9_9 Member
    Aug 5, 2006
    2,599
    Perth , St James
    well im guessing the 430w is a thermaltake so not that great either
  15. ironized
    ironized Member
    Sep 2, 2008
    756
    WHY DO PEOPLE HATE MY PSU? :(
  16. Davo1111
    Davo1111 Member
    Mar 5, 2009
    3,018
    as per above
  17. 2_stroke
    2_stroke Member
    Aug 9, 2008
    1,336
    Wangaratta vic 3677
    lol they beat some of the more dodgy ones out there :) Well they are less likley to catch fire.
    neK
    neK Member
    Feb 3, 2005
    2,910
    Its an Enermax Noisetaker 430w. Not some crappy thermaltake.
  19. Butcher9_9
    Butcher9_9 Member
    Aug 5, 2006
    2,599
    Perth , St James
    well you dodged a bullet there
    not so bad then, still recon a 160w psu can only be so inefficient
