What do i need for htpc?
Discussion in 'HTPC' started by leathal, Aug 16, 2009.
  1. leathal
    leathal Member
    Jun 8, 2009
    177
    G'day guys...
    Just got a New Samsung TV...
    Thought about popcorn hour but think a HTPC would be better...
    Now what is needed for a HTPC?
    So i presume MOBO,
    CPU,
    GPU (will be upgrading my 8800gt so this might do),
    Lots of HDD,
    Optical,
    PSU,
    Case, Maybe Mini P180 White, i have a spare Antec 900 but i think it will be to noisy...
    Sound??? What if i want to buy a HT in a months time?
    I under stand parts dont need to be expensive but what should i be looking for.
    Whats the deal with a Tuner card, do i need one? Is their any difference between connecting the antenna to the Tuner card or the TV its self?
  2. stevo4
    stevo4 Member
    10,631
    leathal
    leathal Member
    Jun 8, 2009
    177
    10 char char
    leathal
    leathal Member
    Jun 8, 2009
    177
    This is back on the agenda... Please help
  5. Pablo_H
    Pablo_H Member
    Jul 13, 2002
    2,766
    wa
    Tuner card is for recording tv shows and movies onto your HDD.
    You can either get a small case that unobtrusive and fits in with your amp/dvd/TV etc.
    Or a large tower with good airflow/cooling that you can use large quiet fans and CPU heatsink.
    You can use windows vista or 7 with windows media center, or linux with myth TV
    edit: As far as components, anything modern can be a HTPC just for regular TV content and DVD, but you need more grunt if you are dealing with bluray and ripping HD content
  6. CrazyDez
    CrazyDez Member
    May 13, 2004
    3,076
    Hockeystan
    Your 8800GT will handle it, but won't output sound, and is too hot and noisy for your needs. I recommend a video card that is passively cooled.
    The newer 5 series ATI cards will output audio over HDMI, and should be compatible with an AV receiver.
  7. stevo4
    stevo4 Member
    10,631
  8. Oppressa
    Oppressa Member
    Jun 5, 2004
    5,573
    Why not get a mobo with built-in GPU? Save $ and fanless so no noise.
  9. stevo4
    stevo4 Member
    10,631
    ^^^ Any with a 5xxx series GPU out yet?
    leathal
    leathal Member
    Jun 8, 2009
    177
    I was thinking the i3s or something
  11. samo
    samo Member
    Aug 20, 2007
    1,482
    I like the ION Zotac boards but if you're looking at i3 then a H55 board may be best for htpc purposes.
