What do i need to run Cyberpunk 2077 100+FPS?
Discussion in 'Newbie Lounge' started by ScqueezeGamer, May 20, 2020.
  1. ScqueezeGamer
    ScqueezeGamer Member
    Sep 3, 2018
    8
    Hi all!
    Just need a little help i don't know much about PC's but i would like to know what i can do to upgrade my current gaming PC to run Cyberpunk 2077 when its released so it looks amazing and runs really smooth?
    These are my current specs :
    Operating System -
    Windows 10 64-bit
    CPU -
    Intel Core i7 4770K @ 3.50GHz
    Haswell 22nm Technology
    RAM -
    16.0GB Dual-Channel DDR3
    MotherBoard -
    ASRock Z97 Extreme4 (CPUSocket)
    GFX -
    2047MB NVIDIA GeForce GTX 1060
    Monitor -
    AGON AG271QG4 (2560x1440@75Hz)
    Storage -
    447GB KINGSTON SA400S37480G (SATA-2 (SSD))
    931GB Seagate ST1000DM003-1CH162 (SATA
  2. asho444
    asho444 Member
    Feb 7, 2012
    1,509
    Sunny Coast
    Time machine to take you to September?
    Sledge, stiben and jjjc_93 like this.
  3. Suopermanni
    Suopermanni Member
    Nov 3, 2010
    414
    Brisbane, Australia
    I don't think the developers have even released official system specifications for Cyberpunk 2077, so it might be a bit premature to ask.
  4. jjjc_93
    jjjc_93 Member
    Jul 3, 2009
    2,184
    Ryzen 4950x and 3080ti should handle it
    VirtualNinja likes this.
  5. Samicans
    Samicans New Member
    Mar 22, 2020
    17
    SA
    chuck ddr3 out and that mobo and upgrade to ddr 4 (its like 4 times faster)
  6. goodplay
    goodplay Member
    Nov 26, 2011
    50
    Sydney 2170
    The 2018 demo specs,
  7. havabeer
    havabeer Member
    Dec 12, 2010
    5,645
    why do you need 100FPS if you monitor is limited to 75?
    either way for 1440P @ 100FPS i'm betting you're going to want to 2080ti, 2080 or 1080ti depending where you want to move the graphics slider from low, medium, high or ultra.
  8. Beavis_Wolf
    Beavis_Wolf Member
    Sep 6, 2007
    110
    Adelaide SA
    With those specs I would want it massage my balls while playing the game
    ae00711 likes this.
  9. goodplay
    goodplay Member
    Nov 26, 2011
    50
    Sydney 2170
    Found another article that mentions the demo was 4K Res.
    Guess that explains the high spec used ?
  10. chook
    chook Member
    Apr 9, 2002
    2,136
    Official requirements have not yet been released. This was published at https://www.gfinityesports.com/arti...m-requirements-recommended-specs-and-pc-setup and is probably reasonable.
    • CPU: Intel Core i5-4670K 3.4GHz / AMD Ryzen R5 1600
    • RAM: 16 GB RAM
    • HDD: 70 GB of space
    • GPU: AMD Radeon RX Vega 64 8GB or NVIDIA GeForce GTX 1070
    • OS: Win 10 64
    • Direct X: Version 11
    • Screen Resolution: 1080p
    I am hoping that I can upgrade my 1080Ti to a 3080Ti or equivalent for release but that doesn't exist yet. If necessary I will continue slumming it with the 1080Ti as going to a 2080Ti at this stage would be silly I think.
  11. havabeer
    havabeer Member
    Dec 12, 2010
    5,645
    Im praying for decent sli support
  12. Rod M
    Rod M Member
    3,622
    there was a 2gb 1060 ??
  13. rireland
    rireland Member
    Jul 11, 2003
    135
    Save up to buy the best rig you can when it's out. Here's hoping the gameplay and visuals will be worth it.
  14. Utetopia
    Utetopia Member
    Jun 18, 2004
    2,698
    BNE/TWMBA
    It'll be far more mainstream required than expected. If it's similar to TW3, the GPU will define performance.
