What is a contactor coil(K) with 3 contacts...
Discussion in 'Electronics & Electrics' started by Silhorn, Feb 14, 2010.
  1. Silhorn
    Silhorn Member
    May 15, 2008
    266
    Hi,
    I have a question on something i am studying and it says to draw the symbol of a contactor coil (K) with 3 contacts.
    Is this referring to a relay with 3 contacts?
    If so, the only thing i can find is this:
    http://www.kpsec.freeuk.com/symbols/relay.gif
    Is this what the question is referring to?
  2. Sleepy Dude..
    Sleepy Dude.. Member
    May 5, 2008
    1,669
    Parramatta,NSW Status:MIA
    on/off/Signal?
  3. Code_Nerd
    Code_Nerd Member
    Nov 20, 2006
    375
    Newcastle
    The drawings I have seen and do use the symbol you have linked to for a contactor coil.
  4. Symon
    Symon Castigat ridendo mores
    Apr 17, 2002
    5,004
    Brisbane QLD
    If you are using AS symbols what you linked to is a relay.
    The coils are drawn the same, but the actual contacts are drawn differently. Contactors have a semicircle on the contacts, instead of the triangle shape.
    Silhorn
    Silhorn Member
    May 15, 2008
    266
    ok so this is the correct symbol except it has semicircular contacts than arrows.
    But, i think this only has 2 contacts doesn't it? What would a 3 contacts one look like?
    I just seen another question which says to just draw a "contactor contact". Ehh, i am confused.
    (Sorry, i am new to electronic diagrams, and only small part of my study covers this ATM)
    Also, does anyone know of a website where it has a list of australian electrical symbols?
  6. Odje
    Odje Member
    2,298
    And it has 3 poles or 3 separate sets of contacts.
  7. FireTech
    FireTech Member
    Feb 6, 2005
    1,651
    Sunny Sydney
    The term 'contactor' is normally used for an AC device and 3 contacts would usually indicate it was for 3 phase use. Normally a 240v AC coil with 415v rated contacts.
    If they wanted a drawing of a 'relay' surely they'd use that term?
    Google revealed this but there may be more sources: http://www.ee.latrobe.edu.au/~gt/ele1edp/Lectures/Electronic-Wiring.pdf
  8. Code_Nerd
    Code_Nerd Member
    Nov 20, 2006
    375
    Newcastle
    What does the number of contacts have to do with phases?
  9. LostBenji
    LostBenji Member
    Oct 5, 2007
    6,084
    Up a tower somewhere....
  10. Code_Nerd
    Code_Nerd Member
    Nov 20, 2006
    375
    Newcastle
    I think you are maybe thinking of terminals?
    The 'contacts' of a contactor are used by external devices to convey that the contactor has been pulled in e.g. PLC, Lights etc.
    See very quick example below of a contactor and 3 contacts being used in a motor starting circuit.
  11. FireTech
    FireTech Member
    Feb 6, 2005
    1,651
    Sunny Sydney
    Terminals are the fixed connections on the contactor that the cables are fastened to using screws.
    Contacts are the fixed or moving pads (usually coated copper) within the contactor which physically connect or disconnect when the coil is energised or de-energised.
    The main ones are rated for the supply to the motor/lighting etc and auxiliary contact are used for signalling, hold on circuit etc. They're still contacts.
    The top three symbols adjacent the motor are the main contacts and others are just auxiliary contacts.
  12. Code_Nerd
    Code_Nerd Member
    Nov 20, 2006
    375
    Newcastle
    When referring to a contactor with 3 contacts, 99% of the time you are talking about the auxillaries and not the main supply contacts.
  13. Goth
    Goth Grumpy Member
    Jun 22, 2002
    9,228
    /dev/null
    This is a little off topic... but what exactly is a contactor?
    My understanding is that it's basically just a very large relay with a 240VAC low-current coil and very large, high current contacts that can switch large amounts of current at 240VAC (or higher voltages), right?
  14. FireTech
    FireTech Member
    Feb 6, 2005
    1,651
    Sunny Sydney
    I tended to refer to them as 2 pole, 3 pole, 4 pole contactor without really referring to (auxiliary) contacts unless there was a specific requirement for an additional auxiliary module.
    Basically, yes. See Wiki below.
    http://en.wikipedia.org/wiki/Contactor
    They didn't have Wiki's when I was an apprentice. Come to think of it, we barely had personal computers back then either... :lol:
    Another difference is that contactors can be usually be maintained (replace coils, clean the contacts etc) whereas relays are usually disposable.
  15. Symon
    Apr 17, 2002
    5,004
    Brisbane QLD
    Correct. The contacts are silver plated copper pads that are brought together by the energisation of the coil. Notice on the drawing how the contacts have a little semicircle on the left hand line - the semicircle means it's a contactor (ie, high current), unlike the auxilaries which don't have it and thus are low current.
    Correct again, especially with the pole comment. With contactors the number of contact sets are called poles, so you have 2, 3 and 4 pole contactors. It's confusing if you specificy contactors by the number of contacts as you can have heaps of auxiliaries, so the way to do it is something like 3 pole + 2 NO, 4 NC for a 3 pole contactor with 2 normally open contacts, and 4 normally closed contacts.
    The way I explain it to apprentices is that relays go 'click click', but contactors go 'clunk clunk' :)
    Voltage doesn't really have anything to do with it, you can get contactors for 12V power systems. Basically relays operate in control circuits to switch small currents, contactors operate in power circuits to switch large currents.
  16. LethalCorpse
    LethalCorpse Member
    Mar 23, 2003
    3,768
    Rochester, NY
    This is all true, but still doesn't define the difference between them. I've also been a little hazy on the difference in terms of operation, though I could pick them out of a lineup without difficulty
  17. Pablo_H
    Pablo_H Member
    Jul 13, 2002
    2,766
    wa
    maybe another difference is contactors are modular (can add auxillary contacts, can attach an overload). They are open (can change the relay coil for repair or to a different voltage) and other things can be repaired or replaced, ie easily field disassembled.
  18. 2xCPU
    2xCPU Member
    Jan 21, 2005
    3,328
    Saigon
    No.
    There is no intrinsic difference between a contactor and a relay.
    It's exactly the same as the difference between a 'capacitor' and a 'condenser' or '1 Hz' and '1 CPS'. The names were simply adopted by different industries so long ago that the they have stuck.
    Symons 'click click' vs 'clunk clunk' differentiation is as good as any to tell them apart.
    It comes down to who uses them/where they are used rather than and physical or electrical difference.
    2.
