What material are computer fans made out of
Discussion in 'Overclocking & Hardware' started by MEX, Jul 15, 2010.
  1. MEX
    MEX Member
    Dec 23, 2001
    1,157
    Perth, WA
    This may sound like a stupid question but bare with me.
    I know some of the cheap fans are just simple cheap plastic but the better ones are usually made from what seems to be some kind of resin ?
    the material i am talking about can be best described wen you screw them into a case. cheap plastic fans sound and feel smooth as the screw cuts into the plastic, the other type which i am trying to identify the material of have a gritty sound and feel.
    also cheap fans you can bend the plastic quite a lot before it breaks the good ones are quite fragile and snap off rather than bend.
    I figure its some kind of composite plastic.
    Any help would be much appreciated.
    Regards
    Luke
  2. Linkin
    Linkin Member
    Apr 25, 2010
    6,344
    Um... they are all made of one kind of plastic or another, I'd assume. Also, fans that have the fins break of easily are not high quality...
  3. carbon_death
    carbon_death Member
    Mar 9, 2009
    992
    Melbourne, Victoria
    I know what you mean, i broke two fins off an Noctua 80mm and it took no force (by accident obviously).
    Ive broken fins on cheaper cooler master clear plastic fans and they do bend a little before snapping.
  4. Hive
    Hive Member
    Jul 8, 2010
    5,142
    ( ͡° ͜ʖ ͡°)
    Some kind of treated PVC or plastic
  5. thormania
    thormania Member
    Jun 12, 2004
    839
    Sounds like the best of both worlds is the soft casing and the harder fins - easy to screw - less noisy to spin?
    :p
    Be hard to find out the plastic types - i guess if you really wanted to try emailing noctura/noiseblocker/premium fan company and see what happens.
  6. Hive
    Hive Member
    Jul 8, 2010
    5,142
    ( ͡° ͜ʖ ͡°)
    Who would screw case fans?
  7. carbon_death
    carbon_death Member
    Mar 9, 2009
    992
    Melbourne, Victoria
    Shal I draw you a pain-ful looking diagram? :D
  8. Hive
    Hive Member
    Jul 8, 2010
    5,142
    ( ͡° ͜ʖ ͡°)
    Why sir that would be excellent
  9. jozlod
    jozlod Member
    Jan 5, 2010
    163
    Newcastle
    *waits for diagram*
    i've had fan blades fall off some old amd cpu fans when using abit too much compressed air near them when de-dusting, then fans end up been quite unbalanced then :(
  10. Hive
    Hive Member
    Jul 8, 2010
    5,142
    ( ͡° ͜ʖ ͡°)
    I wa playing around inside my poweredge 1750 and accidentally touched one of the dual blade 40MM fans running at 8000RPM...
    One of the blades came off
    And so did my finger nail
  11. MyDixiesNormous
    MyDixiesNormous Member
    Jan 21, 2003
    2,419
    Melb
    Some of them are a glassfiber plastic composite.
  12. Hive
    Hive Member
    Jul 8, 2010
    5,142
    ( ͡° ͜ʖ ͡°)
    This is what they are generally made out of
    MEX
    MEX Member
    Dec 23, 2001
    1,157
    Perth, WA
    this would be my best guess as well :)
    Thanks for all the input
    Luke
  14. Vladimir_Putin
    Vladimir_Putin Member
    Jan 29, 2009
    21
    I had a Delta 250cfm fan and a zippy tie got sucked into it, broke 3 fins then I tried to super glue then back on but they just snapped off again also taking off another fin was quite a sad moment.
  15. juscal
    juscal Member
    Dec 11, 2008
    872
    Victoria
    Coolermaster LED silent fans are bulletproof as all fuck. They run at 2000rpm and hurt when you stick your finger in at the sharpest point of the blade. <_< And yet they still dont break.
  16. Life_Essence
    Life_Essence Member
    Mar 4, 2010
    1,495
    I can second that notion, as well as the fans that are used in the Zalman CNPS8700NT.
  17. Smiley__24
    Smiley__24 Member
    Aug 21, 2009
    105
    You'll find that most fans are made from a similar plastic, it's the % of "glass fill" that determines how flexible/brittle the plastic is. Glass fill is basically very fine strands of glass, similar to fiberglass, just much finer. The higher the glass fill % the less flexible/more brittle the plastic is.
  18. Jarwedy
    Jarwedy Member
    Nov 22, 2003
    1,007
    Rockhampton, QLD
    Agreed, though they are really flexible aswell.
    You also tend to find high-rpm fans have brittle/non flexible fins. I remember sticking my finger into a 3500RPM 80mm Sunon fan, no fins broke but my finger copped a nice gash.
  19. AMLagonda
    AMLagonda Member
    Jun 15, 2002
    2,251
    Perth, South of the River
    Nylon is flexible but glass fill nylon is not, fans that flex in a PC would vibrate as a guess. Its probably 5% glass fill.
    They could use high density polyurethane but it could flex as well.
    ABS is impossible to work with on such small thin item like a fan blade.
  20. bonox
    bonox Member
    Jul 14, 2001
    3,344
    everything vibrates - changing the stiffness only changes the frequency at which the vibration occurs.
    The stronger the material you use (the higher speed units where the blade acceleration goes up with square of rotation speed) and the bigger units (inverse relationship with radius) use stronger materials - ie they tend to use chopped (glass) fibre reinforcement. The stiffer or stronger a material is, the more brittle it is (or the lower its fracture toughness).
    There is another factor as well for long life and that is creep - plastics under constant load tend to permanently stretch over time. You cope by making high blade tip clearances to the casing (which increases noise and reduces efficiency), or you use a stronger but more brittle material.
