what motherboard for an i5 2500k overclock?
Discussion in 'Overclocking & Hardware' started by zdream, Sep 3, 2014.
  1. zdream
    zdream Member
    Jun 1, 2008
    1,969
    as title states i can spend up to 120~ but preferably not more than that, i did a little bit of searching but most of the ones i found aren't sold at umart anymore. Also another question as well what CPU coolers are mostly recommended? i was looking into getting a Cooler Master Hyper 212 EVO but wanted your thoughts. thanks.
  2. c_hegge
    c_hegge Member
    Feb 17, 2012
    492
    NSW
    You can't buy a new s1155 board anymore from anywhere, other than a B75 or H61 board, which won't OC. At least not for that price anyway. There may be a few high end NOS boards on eBay, but they are often a lot more than $120
    For a CPU cooler, go with a Hyper 212
    zdream
    zdream Member
    Jun 1, 2008
    1,969
    how do you suggest i go about getting a mb that will allow OC'ing then?
  4. Moarkill
    Moarkill Member
    Aug 30, 2010
    756
    put it up in the WTB threads. You will find one. And yea ebay used is more or less the only way
  5. Moarkill
    Moarkill Member
    Aug 30, 2010
    756
    as fir the 212 Evo..Its a fairly good cooler for the price but is a pain in the ass to install. I have a NZXT Havik 140 and I rate it very highly for overclocking my 2500k
  6. Madengineer
    Madengineer Member
    May 27, 2011
    14,801
    Then you're doing something wrong. Lol
    I've installed them lots of times and they couldn't be simpler
  7. Moarkill
    Moarkill Member
    Aug 30, 2010
    756
    Im assuming Op is somewhat new to the 212 for aftermarket cooling seeing as he asked here in the first place..The included manual is rubbish and it is NOT a very easy install. Maybe me and hundreds of other people who have posted in forums about the unnecessarily tricky install were simply wrong.
  8. JonnoHR31
    JonnoHR31 Member
    Jan 4, 2012
    195
    Using an AsRock extreme 7 gen 3 here, pretty easy to overclock with and had no troubles pushing my 2600k to 5.1ghz on water. There was one for sale on here recently pretty cheap :thumbup:
  9. sammy_b0i
    Jun 29, 2005
    4,897
    ACT 2905
    Having used a 212+ and a 212 Evo many, many times, I don't think it's difficult to install at all. All of them are confusing the first time you install them, as I remember the manual not being too easy to follow.
    That being said, it'll be more complicated than a push-pin or AMD clip-on heatsink, but you get the performance from the extra minute or so taken to install it.
  10. GoneFishin22
    GoneFishin22 Member
    Jun 28, 2008
    0
    Asus P8Z68-M PRO Z68 4xDDR3 2xPCI-E16 GBL RAID USB3.0 SATA3
    Internet Price:$139.00
    - Umart Milton
    Cooling I like the AIO solutions nowadays:
    http://www.umart.com.au/umart1/pro/Products-details.phtml?id=10&id2=255&bid=2&sid=192289
    http://www.umart.com.au/umart1/pro/Products-details.phtml?id=10&bid=2&id2=185&sid=158526
  11. sammy_b0i
    Jun 29, 2005
    4,897
    ACT 2905
  12. GoneFishin22
    GoneFishin22 Member
    Jun 28, 2008
    0
