What remote to get for htpc.
Discussion in 'Portable & Small Form Factor' started by xc351, Jun 13, 2018.
  1. xc351
    xc351 Member
    Dec 30, 2005
    2,101
    Not to sure were this belongs.
    But I’m after a remote for my htpc. I do use a k400r keyboard. But a simple remote would also have its advantages. Ir or Bluetooth ect would work.
  2. nic55
    nic55 Member
    Dec 29, 2005
    77
    Search "media center remote" on ebay/aliexpress and have a look. Any remote that sticks to the MCE standard will pretty much universally work.
    This is how I found my current remote ~8 years a go, it's starting to wear out though and I'm leaning toward https://flirc.tv/more/flirc-usb which lets you map any remote to PC functions, however there is still the problem of finding a comfortable remote with the right buttons for you to map.
  3. guy.incogneto
    guy.incogneto Member
    Nov 14, 2007
    4,851
    Logitech harmony remotes with bluetooth work well. Also less remotes to handle.
