What software fan speed control tools are people using? (loud AIO water cooler fans)
Discussion in 'AMD x86 CPUs and chipsets' started by memnoch, Sep 24, 2019.
  1. memnoch
    memnoch Member
    Jan 4, 2002
    518
    Sydnet
    What software are people using on x570 boards to control their CPU fan speeds?
    I have a deep cool AIO water cooler. However the fans on this spin up and down frequently making the system overall quite loud.
    I have a gigabyte x570 pro wifi board.
    Whats the best way to manage the fan speeds and the noise they produce?
  2. dr_deathy
    dr_deathy Member
    Apr 27, 2007
    3,005
    make the fan curve flat, so turn it up as high as you like straight up then flatten it out then ramp up at 70C.
    You will prob find most good fans go 50% without much noise and a stable RPM is better then constant revving.
  3. Mjollnir
    Mjollnir Member
    6,313
    Melbourne, VIC3104
    Using the Gigabyte SIV - System Information Viewer software.
    terrastrife likes this.
  4. terrastrife
    terrastrife Member
    Jun 2, 2006
    18,819
    ADL/SA The Monopoly State
    As above, use SIV/Smart Fan Control to create a custom curve, then copy them into BIOS so you can then uninstall the software.
    oh wow necro post, how did it go?
