Whats the point of 8x phase over 16x phase?
Discussion in 'Electronics & Electrics' started by Pengoz, Jul 19, 2008.
  1. Pengoz
    Pengoz Member
    Apr 27, 2003
    4,320
    Hell
    G'day
    I see motherboards tout they have 16 Phases over their rivals 8 phases on their motherboard. I believe it has something to do with power modulation?
    Can someone explain for me what the benefits of having more phases on a motherboard is meant to achieve. From what I read having 16 is "overkill". If its to make power more stable on the board then I guess its a good thing?
  2. alvarez
    alvarez Member
    Jun 25, 2006
    2,622
    Geelong 3218
    When it comes down to it, Its just basically marketing speak.
    Pengoz
    Pengoz Member
    Apr 27, 2003
    4,320
    Hell
    So there is nothing physical on the board? What is marketing putting on a spin on, that gives them an extra 8 phases?
  4. SLATYE
    SLATYE SLATYE, not SLAYTE
    Nov 11, 2002
    26,849
    There are physical differences, but they're largely irrelevant (8 phases is more than adequate for current CPUs). Not all that long ago (Athlon XP era), even 3-phase was perfectly adequate and 2-phase was used for the cheap boards.
    More phases should give smoother power, but once you get past ~6-phase power it's about as smooth as it needs to be even with the most sensitive systems. As was said above, 16-phase power is more for marketing purposes than anything else. Adding more phases is one of those things that doesn't cost too much money, isn't likely to cause any problems, and looks really good on the specifications sheet.
  5. Goth
    Goth Grumpy Member
    Jun 22, 2002
    9,228
    /dev/null
    I fail to see how it's much more than complete marketing bullshit.
    Last time I checked, there is no AC power on a motherboard, so exactly what are they talking about?
  6. oohms
    oohms Member
    Dec 22, 2005
    2,192
    Melbourne 3015
    More phases is good but at 8/16 phases that really is where you get diminishing returns.
    Overvolting a quad on a 3 phase board usually has bad consequences :lol:
  7. ArmoureD
    ArmoureD Member
    Sep 12, 2002
    689
    Earth
    I think they mean phases of power regulation/filtration, ie steps, not AC phases.
  8. dakiller
    8,016
    3844
    All else being equal, you'll get smoother voltage regulation, lower stresses on the capacitors and less power dissipated in the CPU's voltage regulation circuitry.
    Switch mode power supplies work on the principal that you switch the input on and off, storing energy in an inductor and using a capacitor on the output to filter the ripple from the switching, with the size of the capacitor and the frequency you switch at, dictating how much voltage ripple you'll have.
    To get less ripple, you either increase the output capacitor or increase the switching frequency. Capacitors cost lots in terms of board space and price, so you want to make it small and as you can. Increasing the switching frequency, you increase the losses in the mosfet switch as it can't turn on and off instantly, so in the period that it changes to on or off there is power loss.
    A single phase supply has one mosfet switching a single inductor and a single output capacitor. A 2 phase supply has 2 mosfets switching into 2 separate inductors which feed a shared capacitor. Both mosfets run at the same frequency but are 180 degrees out of phase to each other, so that while one is dumping charge into the capacitor, the other is charging up from the supply input. So we've effectively doubled the frequency, halved the size of the mosfet and inductors needed as they only supply half the power each, the capacitor doesn't need to be as large as the time between the ripples is reduced.
    8 phase just means 8 mosfets and 8 inductors that are 45 degrees apart that only supply 1/8th of the power each.
    It all depends on how much they've chosen to skimp on the quality of parts, so you can have a rock solid 2 phase supply or a crap 16 phase supply, so you can't compare the two unless they use identical parts, hence all else being equal, more phases the better.
  9. rainwulf
    rainwulf Member
    Jan 20, 2002
    4,227
    bris.qld.aus
    a 4 phase board with awesome low esr caps can easily beat a 6 phase board with shitty caps.
    You can make up for shitty caps by using more phases, but yea, you get to a point where it makes no difference. The more phases, the higher the resultant switching current is anyway, which makes shitty caps even MORE shitty.
    an 8 phase board with shitty caps will be actually a lot worse then a 4 phase board with good low esr caps.
  10. alvarez
    alvarez Member
    Jun 25, 2006
    2,622
    Geelong 3218
    From reading the odd review by people who seemed to have no idea themselves I gathered it was stages of "filtering"
    But Dakiller and goth know there stuff so there answer should be on the money.
    For all intents and purposes you wouldn't really note any difference expect for the price, Id hazzard a guess that software limitations of even the most hardcore overclocking would be a wall long before the 8/16 phase was.
    And even if you did get that far, for a higher clock most people modify the power sections of the board to go over the CPUs recommended limits anyhow.
  11. Silenius
    Silenius Member
    May 25, 2002
    817
    Audiophiles seem to be extremely hung up about the quality of the power to any unit through which the audio runs.. perhaps 16-phase would make audio quality sound better, or remove some of the noise, or something?
    Not that I'd be able to tell the difference :p
  12. dakiller
    8,016
    3844
    This is only for the CPU, not much to do with audio. You want linear voltage regulation for audio anyway, no stinkin' switcher
