  1. bucket23
    bucket23 Member
    Dec 10, 2008
    95
    I haven't had an issue with cat6A cables and gromming them into the rack.
    You just need to follow the manufactures instructions. If you follow them and there is an issue, then go to the manufacturer.
  2. Aetherone
    Aetherone Member
    Jan 15, 2002
    8,825
    Adelaide, SA
    It's pretty much all simplicity. Media render box here with 10g, bit bucket over there with 10g, a stack of 1g clients hanging off the 1g ports. One simple cable to connect them each to the network, minimal bottlenecking when multiple clients decide to hit the storage silo.
    I'd love a 4+16 port version of the switch but I suspect they're going to need a die shrink and significant power efficiency improvement to achieve that passively.
  3. bcann
    bcann Member
    Feb 26, 2006
    5,966
    NSW
  4. davros123
    davros123 Member
    Jun 18, 2008
    2,930
    fwiw, My tplink with 4 x 10G and 24 x 1G is passive.
  5. Aetherone
    Aetherone Member
    Jan 15, 2002
    8,825
    Adelaide, SA
    How's it handle having the SFP slots stacked with 10GBASE-T transceivers?
  6. davros123
    davros123 Member
    Jun 18, 2008
    2,930
    Good point, I run optical. it's on mydesk and it's cool as a cucumber. It'll be in a rack soon with a POE below and a server above and so we'll see how it like being in tight spaces soon.
    Cpu is pretty low but I at last have most things.
  7. Quadbox
    Quadbox Member
    6,439
    This is a common misconception by the way. Maximum signal speeds for electrical signals moving along a cable and optical signals moving along a fibre are both at the speed of light of the medium in question, which no matter what is lower than the vaccuum (and probably even air) speed of light. (for a 50ohm impedance coaxial cable for example the speed of light is 2x10^8m/s, so 2/3 the vaccuum speed of light, which is still *amazingly* fast)
    There's not an inherently higher latency in *copper* connections, hence why a twinax connection is just as low latency as a multimode fibre connection is (slightly more so, in fact). The latency comes in because making these signals work on twisted pair involves a hell of a lot of trickery to manage noise, crosstalk and dispersion, and so the electronics is just flat out more complicated, once you're up at 10GB. An optical transciever, on the other hand, is comparatively simple electrically (the fact you've got a laser diode in there doesnt really increase latency particularly, and there's a lot less signal processing involved).
    EDIT - (to clarify, twinax on the other hand runs on coaxial cables that are well and truly capable of supporting RF without all the stuffing around. Not that different to antenna pigtails.)
    Luke212 likes this.
  8. davros123
    davros123 Member
    Jun 18, 2008
    2,930
    Plus opticals go 300m and only cost $22 for 10G Intel compat. modules at FS.com and arrive in 2 days for just $8 ;)
  9. evilasdeath
    evilasdeath Member
    Jul 24, 2004
    4,956
    I'd love for this to happen
    https://www.extremetech.com/extreme...ber-for-faster-networks-more-accurate-sensors
    subsea cables would be great, but imagine a cut, would suck in crud and would likely need to lay the whole thing end to end.
    But yes Quad, over Fibre the signal is serialized 64b/66b (https://en.wikipedia.org/wiki/64b/66b_encoding) efficient encoding and very low overhead
    vs
    10G-BASE-T which is (from wikipedia)
    The 802.3an standard specifies the wire-level modulation for 10GBASE-T to use Tomlinson-Harashima precoding (THP) and pulse-amplitude modulation with 16 discrete levels (PAM-16), encoded in a two-dimensional checkerboard pattern known as DSQ128 sent on the line at 800 Msymbols/sec.[52][53] Prior to precoding, forward error correction (FEC) coding is performed using a [2048,1723]2 low-density parity-check code on 1723 bits, with the parity check matrix construction based on a generalized Reed–Solomon [32,2,31] code over GF(26).[53] Another 1536 bits are uncoded. Within each 1723+1536 block, there are 1+50+8+1 signaling and error detection bits and 3200 data bits (and occupying 320 ns on the line)
    All this takes a fraction longer to do than 66b/66b
    This might be a few microseconds which is non issue to most people, but is a measurable difference. Additionally needs more power, again not much in a small situation, but i can tell you in a situations with 100 of these things it's not worth it just to be able to use copper.
    That being said, i used early generation 10G fibre interfaces, cisco xenpaks and gbics :) SFPs are a shit load better!!!
  10. davros123
    davros123 Member
    Jun 18, 2008
    2,930
  11. evilasdeath
    evilasdeath Member
    Jul 24, 2004
    4,956
  12. cvidler
    cvidler Member
    13,969
    Cool thing is while it appears to be complex math, it's easy to implement in hardware so can happen at full line rate (no performance impact, no CPU usage).
    The fancy stuff done to copper 10GE, is all done in hardware too, but still results in more overhead than the fibre encoding.
  13. evilasdeath
    evilasdeath Member
    Jul 24, 2004
    4,956
  14. Quadbox
    Quadbox Member
    6,439
    If you're the sort of person who has a signal generator and a reasonably high frequency capable oscilloscope btw, it's actually relatively easy to do an experiment to determine the speed signals propagate in the cable. It's one of those little physics experiments that I feel's worth actually doing yourself just to convince yourself it's true. Only need about a 100MHz oscilloscope, two ten metre lengths of (50ohm) coax, one t-piece, one 50ohm terminator and one coax shorting end. T-piece in the middle of the two cables, with the oscilloscope attached to it. one end to the signal generator, the other end you can either short, leave open, or put a terminator on. Capture the outgoing pulse and its reflection in the same time sector. It's quite interesting to see the behaviour
    EDIT - of course if you've got a pair of 20 or 30m long coax leads it's even easier :p
    cvidler likes this.
  15. cvidler
    cvidler Member
    13,969
    used to do that with the 10base2 network at school. pull the terminator, watch everyone start complaining.
  16. evilasdeath
    evilasdeath Member
    Jul 24, 2004
    4,956
    ahh the days of school
    We had a classroom full, about 25 PCs, which were these thin clients at the time, they just did touch typing classes and stuff like that. 10Base2 network so it would fall apart all the time when a connector was loose somewhere. Add to the fact that all 25 PCs were on the same circuit breaker!, so if you turned them on in lots of 5 and let them boot it was fine, but turn on all 25 at the same time and it would trip the breaker.
  17. Quadbox
    Quadbox Member
    6,439
    This is why all the cool kids were using tokenring :p
  18. cvidler
    cvidler Member
    13,969
    but if you disconnect the cable, the token would fall on the floor and you'd be stuffed.
    we're blessed with todays' individually switched collection domains, and non-zero latency wifi.
    Aetherone likes this.
  19. karun
    karun Member
    Nov 8, 2011
    130
    Im waiting for Synology NASes to come with 10Gbps Ethernet as standard before having a look at it. Unless the NAS supports it, its not worth changing from Gigabit Ethernet to 10 Gigabit Ethernet.
    MR CHILLED likes this.
  20. Quadbox
    Quadbox Member
    6,439
    A thread necromancer! :p
