  1. OP
    Smokin Whale
    Smokin Whale Member
    Nov 29, 2006
    5,180
    Pacific Ocean off SC
    Well fuck me, LACP doesn't want to work with my D-Link switch. Tried everything. Why is it so hard to get more than 1G :upset:
  2. Copie
    Copie Member
    Jul 24, 2009
    13,726
    Newcastle
    You do know that LACP works when you have multiple pcs drawing from the server? It's technically not one huge connection like 10gb
    Smokin Whale
    Smokin Whale Member
    Nov 29, 2006
    5,180
    I understand that, and I normally have multiple connections running to the same machine, but Server 2012 keeps saying "faulted LACP negotiation". I get no connection whatsoever.
    Probably going to sell the D-Link, buy some cheapo TP-Link switch, forget LACP and just assign a virtual machine to the secondary NIC.
    Anyway back on topic, any recommended SOHO switches with 10G uplink ports?
  4. Dragon_191
    Dragon_191 Member
    Aug 10, 2001
    304
    ACT
  5. Urbansprawl
    Urbansprawl Member
    May 5, 2003
    571
  6. Copie
    Copie Member
    Jul 24, 2009
    13,726
    Newcastle
    Read my earlier post
  7. FiShy
    FiShy Member
    Aug 15, 2001
    9,682
    Windows Is shit at LACP as unlike real OS's you cant set the mode. Spent this week trying tl get tagging and lacp working on some real kit and its a pain so good luck doing it on a shit-link
  8. Annihilator69
    Annihilator69 Member
    Feb 17, 2003
    6,057
    Yep, the CR's pretty sweet, crazy fast.
    If you've never used RouterOS before it can be a bit overwhelming at first.
    Can use GUI or CLI.
    If you're just using it for switching, it's not too hard to work out.
    Smokin Whale
    Smokin Whale Member
    Nov 29, 2006
    5,180
    I have one machine which is running Server 2012 and hosts some accounting and cad based server applications, plus around 10tb of data, 1tb of which gets moved around fairly commonly. I then have a second windows 8.1 box that regularly backs up data from the primary server.
    I typically avoid consumer NAS boxes due to lack of flexibility and performance. The D link isn't supposed to be a piece of crap but for some reason it doesn't want to do LACP. I'm giving up and going back to unmanaged which gave fine single link performance anyway
    Smokin Whale
    Smokin Whale Member
    Nov 29, 2006
    5,180
    So it's 2016 now, where's the 10GBE at :weirdo:
  11. Thrawn
    Thrawn Member
    1,072
    Smokin Whale
    Smokin Whale Member
    Nov 29, 2006
    5,180
  13. Thrawn
    Thrawn Member
    1,072
    Switch is still problematic and rather expensive..
    Great for hooking up 2 computers though. You can even get SFP+ fiber modules for $25 now.... so distance isn't an issue
    Smokin Whale
    Smokin Whale Member
    Nov 29, 2006
    5,180
  15. Dr Evil
    Dr Evil Member
    Oct 20, 2010
    2,855
    Smokin Whale
    Smokin Whale Member
    Nov 29, 2006
    5,180
    Any other switches worth looking at? Specifically, ones with support for UTP/STP CAT6?
  17. cvidler
    cvidler Member
    12,785
    They become expensive, fibre 10Gig is still the cheaper option.
    Netgear have a cheap(ish) 8port for about $1100
    Smokin Whale
    Smokin Whale Member
    Nov 29, 2006
    5,180
    Yup, not exactly sure why copper 10GbE is so much more expensive. Oh well, fibre it is for now.
  19. Thrawn
    Thrawn Member
    1,072
    Copper 10Gbe is also rather power hungry. Something like an additional 5 watts per port in comparison to SFP+
  20. Copie
    Copie Member
    Jul 24, 2009
    13,726
    Newcastle
    You can get the xs708 cheaper then that cheapest I've seen is around 900 bucks or so for it.
    Otherwise troll grays and you might get lucky on a dell or Cisco 24 port.
