  1. evilasdeath
    evilasdeath Member
    Jul 24, 2004
    4,999
    While this is a problem its more a factor of lack of demand, very few people want 10g copper.
    In the consumer space there are very few devices that have 10g copper, let alone have the capability to push it beyond 1gbit and see benefits in it.
    In the enterprise side its much the same
    The place that 10g+ is getting used heavily is in datacentres, but they want high density and low power, and power is mentioned again, i think its more the fact that dcs dont like copper interconnects either, you can put a lot more fibre into a rack compared to copper, even within the rack its easier to route and manage fibre vs copper. As such the development of 10g has been mostly towards fibre vs copper
  2. cvidler
    cvidler Member
    15,066
    yeah 1100 is rrp.
    one thing to look for when scoping old gear is what modules they take.
    There's been more than a few standards over the years. X2, XFP, SFP+.
    SFP+ has 'won'. Resulting in the cheaper and more readily available modules.
    X2 and XFP are still around, but are usually more expensive and harder to find.
    tl;dr; get a switch that uses SFP+ modules.
  3. Copie
    Copie Member
    Jul 24, 2009
    14,329
    Newcastle
    Well that and also module brands matter some don't play well with other brands either
  4. HobartTas
    HobartTas Member
    Jun 22, 2006
    1,054
    Smokin Whale
    Smokin Whale Member
    Nov 29, 2006
    5,184
    Pacific Ocean off SC
    Is there a particular reason why the "HP 10GB MELLANOX CONNECTX-2" is quite cheap at the moment? Seems like there are some companies dumping stock.
  6. HobartTas
    HobartTas Member
    Jun 22, 2006
    1,054
    If I had to guess its because Mellanox have now recently stopped selling QDR IB adapters and switches and most of the IB cards were 40GbIB / 10GbE capable, and I'm guessing that these 10GbE standalone network cards were part of the same "technology family" and hence they also get to be junked as well. Although this is probably good news for people that wish to purchase them both cheap and new right now. Their base IB cards are now FDR speeds of 56GbIB / 40GbE.
    Smokin Whale
    Smokin Whale Member
    Nov 29, 2006
    5,184
    Yeah definitely, I'm thinking of purchasing a couple for the new office. Pretty crazy that they are already pumping out dual 100Gbe cards in their new line, that's enough to easily saturate a 16x PCIe 3.0 slot (assuming full duplex with traffic going both ways).
  8. fad
    fad Member
    Jun 26, 2001
    2,539
    City, Canberra, Australia
    This is where NBASE-T might help. It should require the same spec cables. With just a bit more speed. So 80m+ lengths should be fine, but it will only be 2.5gbit or 5gbit.
    However I don't know when it will turn up. I think until the war is won and they start producing Intel NICS on desktops with this, it wont go far. There are two competing standards. NBASE-T vs MGBASE-T
    Smokin Whale
    Smokin Whale Member
    Nov 29, 2006
    5,184
    Very interesting, thanks for sharing. Classic format wars. It's pretty clear that with fibre internet speeds and 4k VR around the corner, 1GB LAN isn't going to cut it anymore (and definitely is an issue for most people who work with multimedia on a network). 2.5Gbit or 5Gbit would be plenty for most households and compatible with the existing internal wiring.
  10. fad
    fad Member
    Jun 26, 2001
    2,539
    Nbase-T seems like the obvious choice, its the same protocol as 1GBase-T with a faster clock. Uses the same wiring type as 1Gbe and will support previous versions. So a Nbase-T device will connect to a 1Gbe device.
    The cons are Broadcom is in the MGbase camp. Considering they are a huge player, they have alot of weight.
    It also turns out these two camps have forced the IEEE to ratify a standard. So they have announced 2.5Gbase-T and 5Gbase-T. Expect to see something in 24 months.
    Smokin Whale
    Smokin Whale Member
    Nov 29, 2006
    5,184
    24 months can't come soon enough.
  12. HobartTas
    HobartTas Member
    Jun 22, 2006
    1,054
    Yes but I don't think your going to be pumping stuff out at that speed on a sustained basis and what can receive 100 Gb's a second other than a ramdrive or a high end SAN. I think in most cases people are trying to utilise the higher speeds to somewhat mitigate latencies that already exist elsewhere like this here (although probably not the best example I can think of, kindly read the entire thread to understand the problem they had).
    Most people seem to be quite happy with the 53Mb's a second they get off the wireless home router, let alone the 1Gb's from the cat 6 cable.
    These 2.5 and 5.0 speed hardware's were supposed to be coming a couple of years ago and nothing has happened yet. Enterprise users probably won't bother with it because anyone that needed more than the 1 Gb's they get on copper probably already got transitioned to 10 GbE on fibre a long time ago.
    If you look at home users and my previous comment about speeds then what are retailers going to sell? a mix of 1.0 and 2.5/5.0 speed hardware? or are they going to stop selling the 1.0 stuff and replace it altogether with 2.5/5.0 stuff at say a 20% price premium as what retailer wants to sell order/store/sell two SKU's of low margin stuff?
    I know people say that the 2.5/5.0 gear is faster (which it is, and backwards compatible) but even though I could also use it, its really neither here nor there. What I want is to do is something like the following and I will most likely buy the QDR infiniband cards to do something like this for my PC's.
    (1) Remove the local boot SSD entirely, insert the IB card and boot drive C: off an image stored on a ZFS NAS so essentially all the PC's will be diskless workstations much like when 20 years ago people used to insert a boot chip onto the vacant spot on a NE2000 network card in their DOS machine and boot remotely off an image stored on a Netware server.
    (2) Create a small but fast ZFS NAS that probably has a half dozen SSD's in Raid-Z2 and all the PC's boot images and VM's are stored just on this. I can snapshot everything on a regular basis and I don't need to bother with (a) cloning the boot drive in case it dies as that is what the ZFS Raid-Z2 will be there for to prevent, (b) backing up anything as it will already be done with the snapshotted disk images that will periodically also be copied to the spinners and (c) worry about Cryptolocker type viruses as I can always go back to a previous version. Other bulk data can be stored on spinners also in Raid-Z2 either on the same NAS or probably a separate one that's not on all the time.
    In case anyone thinks this scenario is a bit "out there" I'm not the only one asking and someone else is already doing this.
    Cheers
  13. MoRpHeUs
    MoRpHeUs Member
    1,892
    Perth, Western Australia
    So in summary 2 years later still no consumer priced 10Gbe as per original thread starter?
  14. Gunna
    Gunna Member
    Dec 25, 2001
    7,844
    Demand will often drive competition which in turn drives down price.
    The demand for 10Gbe at a consumer level is low. Most users rely on connectivity via either their ISP supplied modem and wifi. Users who need speed move to Gbe but generally the need for consumer 10Gbe is very low i would think.
  15. nav
    nav Member
    Aug 20, 2001
    4,330
    melbourne
    Thanks for the thread revival, made for pretty interesting reading. :thumbup:
    See you all in 24 months !
    -nav.
  16. Luke212
    Luke212 Member
    Feb 26, 2003
    10,141
    I can fill 100Gbs in compute clusters very easily when going from ram to ram or gpu to gpu. its a significant bottleneck really.
  17. Gunna
    Gunna Member
    Dec 25, 2001
    7,844
    Running that Token Ring are we?
  18. Hive
    Hive Member
    Jul 8, 2010
    6,367
    AvE
    We probably won't see it mainstream until 2020.
    If you want 10G on the cheap - there's always IP over infiniband, or CX-4 crap (think 802.3ak?)
  19. evilasdeath
    evilasdeath Member
    Jul 24, 2004
    4,999
    should we start a thread for when will we see 100g in consumer cheap?
  20. Hive
    Hive Member
    Jul 8, 2010
    6,367
    AvE
