  1. cvidler
    cvidler Member
    13,533
    With MS yeah.
  2. Renza
    Renza Member
    Dec 1, 2004
    4,734
    at the OS level, yes. bt if your NICs support it at the driver level, then it will work on desktop OSes as well
    Smokin Whale
    Smokin Whale Member
    Nov 29, 2006
    5,182
    Pacific Ocean off SC
    Derp, didn't see the 10g copper ports. The trendnet switch is still several hundred dollars cheaper though, although I've never used a managed trendnet switch before...
    The answer to the second is "sort of". SMB multichannel seems to be a bit of a hit and miss for some, depending on NICs, drivers, switches and OS versions. It's one of those things that should just work, and it does for the most part, but it's useless in certain situations. One thing I keep seeing is that it doesn't seem to load balance automatically for some, and MS are still fiddling around with the implementation of it. I honestly haven't played with it much, but I know that my current fileserver can make use of it if I have multiple concurrent transfer streams from it. Dual Intel NICs on an Intel S1200BTL motherboard
  4. Luke212
    Luke212 Member
    Feb 26, 2003
    9,823
    why dont you run the desktops in RDP or similar, instead of spending huge amounts on networking? or better, put the ssds in the Workstations and just manage them as workstations? your software is specific... scientific modelling. you might be making pain for yourself in the future if you don't just do the standard high perf workstation storage for them.
    Smokin Whale
    Smokin Whale Member
    Nov 29, 2006
    5,182
    What? We run a repair shop. Sometimes we have 5 customer SSDs/HDDs backing up to our server at once, and 3-4 SSDs imaging at the same time, and then we have to restore customer data after the image is complete. Things usually aren't that hectic, but sometimes it happens, and LAN performance becomes an issue. Driver updates and what-not are also done by the server. Currently we have large SSDs in the workstation and image locally, but I'd rather just make things simple and just have a stupid fast fileserver.
  6. TehCamel
    TehCamel Member
    Oct 8, 2006
    4,183
    Because he images devices and runs a small break-fix shop?
  7. Luke212
    Luke212 Member
    Feb 26, 2003
    9,823
    i thought you were that science guy asking about single thread perf in another thread :o yes, make sense to have a good/fast backup server when doing your sort of work.
  8. scottath
    scottath Member
    Aug 16, 2007
    2,575
  9. Hive
    Hive Member
    Jul 8, 2010
    6,053
    AvE
    Knowing ubiquiti, it will be fairly affordable. :thumbup:
  10. NSanity
    NSanity Member
    Mar 11, 2002
    17,968
    doubt it will be under Netgear.
    And honestly SFP's are canceer.
  11. Hive
    Hive Member
    Jul 8, 2010
    6,053
    AvE
    SFP Direct attach is alright, otherwise modules are expensive. RRP looks to be around 599 AUD.
  12. Aetherone
    Aetherone Member
    Jan 15, 2002
    8,732
    Adelaide, SA
  13. Sphinx2000
    Sphinx2000 Member
    Sep 16, 2001
    9,084
    Pricing is STILL nuts... no take-up = high price = no take-up. :thumbdn:
  14. cvidler
    cvidler Member
    13,533
    this still not a thing.
    here's me deploying 100GE 'storage*' network, with mutli 40GE server links
    seriously for consumer/home level the place to be is second hand market
    *it's really more network attach RAM. 56GB/s (that's a big B). microsecond latency.
  15. Aetherone
    Aetherone Member
    Jan 15, 2002
    8,732
    Adelaide, SA
    Cheap(ish), large, hot and noisy as hell. Maybe its not. :thumbdn:
    Sexy. Got photos? :D
  16. Hive
    Hive Member
    Jul 8, 2010
    6,053
    AvE
    What needs to die is 2.5/5 GB ethernet tech. Biggest waste of anything ever. NO MIDDLEGROUNDS, UP ALL THE RATES.
  17. Aetherone
    Aetherone Member
    Jan 15, 2002
    8,732
    Adelaide, SA
    I think that depends on where its going to settle in at what price-point.
    New tech has always been stupid expensive but 10g really hasn't dropped like previous. If it had followed the same timeline, we'd be getting >$200 desktop boards with rubbish RTL 10G chipsets soldered on about now :D :sick:
  18. Hive
    Hive Member
    Jul 8, 2010
    6,053
    AvE
    just imagine the CPU usage...:thumbup:
  19. fad
    fad Member
    Jun 26, 2001
    2,387
    City, Canberra, Australia
  20. elvis
    elvis Old school old fool
    41,441
    Speak for yourself. We're rolling out 10GbE to the desktop in the absence of anything between 1GbE and 10.
    Considering a 1GbE PHY is $3, and a 10GbE NIC + cable + SFP connectors puts us at about $200-300 per desktop, there's a lot of room in the middle.
    Realistic draw for our workstations is around the 2-3Gbit/s per person mark. 1GbE is too slow, LACP is a pain in the balls, and 10GbE means extra cost for overhead we don't need.
    2.5/5Gbit/s would be *perfect* for us right now.
