Why are testicles so badly designed?
Discussion in 'Science' started by ddk, Mar 11, 2013.
  1. elvis
    elvis Old school old fool
    41,802
    It genuinely bothers me that more people don't understand this.
    There seems to be a belief amongst the masses that evolution is geared toward some sort of concious decision making process that has the ability to read the future, and create things based on some possible future need.
    Likewise, there is a similar belief that just because some body part evolved into its current form, it's necessarily "superior" to some other option, ignoring the being as a whole, and the concept of being old/functional enough to reproduce, and then being evolutionarily useless after that point.
    Evolution is not "smart". It is merely random, circumstantial, and very basic in its requirements.
  2. luxtin
    luxtin Member
    Aug 10, 2003
    6,756
    In battle there are a lot of better spots to target than the groin to disable someone. There is no reason to protect them from attack only accident, but this wouldn't happen on a large enough scale to change a population, maybe if they were hanging off your elbow but not in the groin.
  3. breno
    breno Member
    May 3, 2011
    1,707
    Maybe in the future, we can genetically modify our male children to have their testicles grow on the inside to save them from the agony and getting 'smacked in the balls'.
    Let's make 'getting smacked in the balls' history!
  4. holdennutta
    holdennutta Member
    Apr 14, 2002
    7,757
    It's also troubling how little people understand about how their body works.
    ddk
    ddk (Banned or Deleted)
    Dec 7, 2011
    1,570
    Who here said it was 'smart'?
    I said it didn't make evolutionary sense. That it seems to be something that would inhibit reproduction and therefore would result in an evolutionary dead-end.
  6. Tinian
    Tinian Member
    Jan 3, 2009
    19,447
    15.0° N, 145.63° E
    On the contrary. Given the amount of animals that have their testicles outside of their body, it seems to have made perfect sense as that's the design that won.
  7. holdennutta
    holdennutta Member
    Apr 14, 2002
    7,757
    Are you yourself not proof that you're wrong about that?
    ddk
    Dec 7, 2011
    1,570
    And my question is, "Why?"
    Care to explain in greater detail and clarity what exactly you mean by that comment?
  9. Tinian
    Tinian Member
    Jan 3, 2009
    19,447
    15.0° N, 145.63° E
    Yes, we got that in the first post and a number of theories have been provided.
  10. doubter
    doubter Member
    Feb 9, 2013
    213
    If your environment is filled with people with generally the same testicles, then it is not going to make a difference.
    The factor mediating in evolution is the 'environment'.
    Certain evironments foster some people to breed more than others.
    The question is what are the environmental factors that influence the ability for a human to breed and for that child to survive and breed.
    Now those environmental factors are so complex, intertwined (as in, from a materialists perspective, social and physical are one). Think about all the abstracted social aspects, the luck, neuroplasticity, etc etc etc.
    In the context of all that, testicle 'design' means nothing really. So it is irrelevant in relation to making 'sense'. If you wanna make sense of our existence and testicles... well good luck really.
    It's almost all luck and bullshit.
    :rolleyes: to you.
  11. The Wolf
    The Wolf Member
    Sep 9, 2011
    449
    Evolutionary pressures have to be long term and sustained. Inconvenience is not an evolutionary pressure. An Accident is random and unpredictable, and is not a pressure either. Infertility from everyday activities is rare, ergo the current design is acceptable
  12. TRAG!C
    TRAG!C Member
    Apr 18, 2007
    1,755
    They are not exactly a weakness. Sure if you are looking at MMA a swift kick to the balls will often take a man down but the changes are you can still have kids. Now this may change after several kicks but hey...
    From an evolutionary point of view all it cares about is did you survive until puberty, did you successfully mate. If we go back a couple of thousand years I think the least of our worries was a saber tooth tiger taking a cheap shot to our testicles. So from that point we were far more likely to die than to have a testicle damaged.
    Weigh that against the benefits of external testicles, increased sperm count and reduction in birth defects. Means given 2 equal samples the external testicles are more likely to produce more offspring.
  13. gregpolk
    gregpolk Member
    Mar 4, 2004
    7,403
    Anyway, yes damage to your testes could reduce your fertility and thus having exposed testes could be something that is selected against in populations where damage to testes is likely. This would be balanced against having them internally where they would be less productive and so our fertility would always be lower, except protected, so this would be a trait selected against in populations where damage to testes is unlikely. Now, could they evolve to have the sperm operate at a higher temp? Maybe, but perhaps there are some special chemical reactions that require those temperatures and evolution can't really change physics/chemistry. Alternatively could our body temp lower to suit the internal testes? Maybe, but same problem again, special chemical reactions require those temps, and it would be tough to evolve against that.
    Now, if a loving all powerful god who created the entire universe designed our balls, he could adjust the chemistry and make it all work internally. He is omnipotent after all. But he didn't. Begs the question of why he is so incompetent. Anyone know a bible verse that justifies his poor design skills? Find the one for the recurrent laryngeal nerve while you're at it.
    ddk
    Dec 7, 2011
    1,570
    Ooh, ooh, ooh! I know this one!
    God works in mysterious ways.
    Do I get into Heaven now?
  15. Sipheren
    Sipheren Member
    Aug 14, 2002
    3,426
    Gold Coast
    Also, for the OP, this might shed some light:
    Full Document
  16. OldMate
    OldMate Member
    Feb 12, 2012
    1,422
    Northern Beaches SYD
    maybe he stuffed up?
    I dunno, and I'm a catholic.
  17. Sam_Q
    Sam_Q Member
    Nov 27, 2002
    1,008
    Endeavour Hills VIC
    ok no problem, where are the missing links then? Darwin himself was reported to of said the evidence defies the theory. I should look that up and see if it's a true quote. Explain the dolphins sonar system in evolutionary terms then.
  18. gregpolk
    gregpolk Member
    Mar 4, 2004
    7,403
    There aren't any major missing links because all you're doing is when we find A and B and claim that C fits between you then go AHA now you have 2 missing links of A-C and C-B! If you'd care to point out exactly where you'd like a link, I'm willing to bet with some brief research I could find it, already discovered. So long as you don't expect a fossil of every organism to have ever lived so that there aren't any gaps in the lineage.
    What Darwin thought about the evidence for evolution is irrelevant because he published it in 1859 for christs sake.... We've come some ways since then...
    Do look it up that quote, if I'm thinking of the same one then while you're at it read the next line. He posted an argument against his theory in Origin so that he could then, in the next line, rebut an expected argument against him.
    So yes, in your own time, can you biblicly justify the poor design of the human body? Because biologists can justify it by looking at comparative anatomy.
    Was the quote in this the one you were thinking of?
  19. Aetherone
    Aetherone Member
    Jan 15, 2002
    8,747
    Adelaide, SA
    Its right here :rolleyes:
    Darwin is 150 years outta date; not to mention he predates DNA in its entirety and modern molecular genetics/systematics.
  20. holdennutta
    holdennutta Member
    Apr 14, 2002
    7,757
    You posted:
    The fact you're a human would tend to suggest dangling testes isn't an evolutionary dead end.
