why are there no slim atx cases?
Discussion in 'Newbie Lounge' started by spotted, Oct 23, 2018.
  1. spotted
    spotted Member
    Nov 10, 2010
    332
    Looking around for a slim case, the only information I found was on reddit.
    https://www.reddit.com/r/buildapc/comments/75vnnz/good_slim_atx_cases/do9h6vm
    There is 1 matx case that takes a normal atx psu is Bitfenix Pandora is 160mm. Which btw is discontinued.
    Given that normal ATX have no 5.25 bays anymore, why are they still the same 21cm wide?
    Given 16cm can house ATX PSU, why are 14cm cases like the Core G3 using SFX PSU?
    Is there a reason nobody makes thin ATX, w/o the need for pcie header leads, etc?
    I see fat and short ones, but I don't see the point of 21cm width when we're putting nothing wider than the PSU there.
  2. wintermute000
    wintermute000 Member
    Jan 23, 2011
    1,874
    The manufacturers figure people who want thin are going ITX?
    Also cooler height? Even a humble Hyper212-X is ~160mm, add the mobo / clearance and you're not a lot far off 210mm.
    spotted
    spotted Member
    Nov 10, 2010
    332
    Itx are still uncommon right?
    Are coolers that common now? Only if you o/c right?
    with 21cm apart from losing your old 5.25 bays, you don't seem to gain anything from a new case. Same usb2/3 ports, audio. More glass.
  4. CAPT-Irrelevant
    CAPT-Irrelevant Member
    Sep 7, 2007
    6,147
    What motherboard specifically are you wanting to work with?
    Generally, if you're not going to use the motherboard's form factor for what it's designed for, there's no point getting that particular size.
    spotted
    spotted Member
    Nov 10, 2010
    332
    I have a matx MB. My case is showing start of rusting on the grilles.
    If I'm going to get a new case and lose my 5.25, I expect it to be narrower not wider! (current case is 20cm)
    Also I get the same usb3 ports at the front as my 10 year old case. I just don't know what the point is.
    spotted
    spotted Member
    Nov 10, 2010
    332
    Never looked into itx, assumed it was for those htpc format with no expansion. I want 4 ram slots anyway. I guess I expect if I buy sth at least I get sth new. You can't even seem to get usb3.1v2 ports or usb c ports on cases, or 4x usb3 ports. Nothing much seems changed but moving the PSU to bottom.
  7. pwlm1975
    pwlm1975 Member
    Apr 18, 2016
    366
    Logan, Qld
    Cooler height, GPU width (esp. any with the cables at the side of the frame instead of the rear, which is most of them). Silverstone do a few cases of slimline mATX size, like a larger HTPC case.
    ML03, ML04 from Silverstone are all mATX slim cases which support full ATX PSUs, is that the kind of thing you're after? Pictures below "borrowed" from Silverstone's website.
    ML03
    ML04
    These will take SFF expansion cards, which limits you to an RX 560 or GTX 1050Ti.
    Lack of USB ports in slim cases is by default, as you said I think they're mostly designed for HTPC/1080p gaming machines for lounges. You'd have a wireless dongle /receiver for your keyboard/mouse and one for a controller, that's about it.
  8. wintermute000
    Jan 23, 2011
    1,874
    Itx is everywhere
    spotted
    spotted Member
    Nov 10, 2010
    332
    Yes things shaped like this, but I'd put it vertically under the desk. I'd run USB headers out the back, so I guess if I can find ones that fit...
  10. A Gringo
    A Gringo Member
    Jul 30, 2010
    70
    spotted
    spotted Member
    Nov 10, 2010
    332
    Thanks, that looks good!
  12. im late
    im late Member
    Jan 5, 2012
    1,523
    Canning Vale WA 6155
    This mATX case is only 190mm wide, so this is an improvement over you current 200mm wide case.
    Decent spces for the price too (IMO).
  13. Groff
    Groff Member
    Jun 22, 2012
    107
    NSW
  14. im late
    im late Member
    Jan 5, 2012
    1,523
    Do these have proper/removable dust filters on all usual intake areas?
  15. FNQer
    FNQer Member
    Aug 16, 2002
    1,121
    yes, removable fan filters on GD10... i don't think ML03 has...
    GD10 is a good case, not slim though, like a regular hifi amp. 2 usb3.0 ports at front, audio jack, dvd drive slot....had to squeeze the cabling, EVGA GTX 1070 SC Gaming ASX3.0, 2 x SSD, HDD and DVD drive in tight. not vertical, either.
    does lian li not have some slim, vertical mATX?
  16. Groff
    Groff Member
    Jun 22, 2012
    107
    NSW
  17. Groff
    Groff Member
    Jun 22, 2012
    107
    NSW
    The MLs don't. The GDs do.
  18. pwlm1975
    pwlm1975 Member
    Apr 18, 2016
    366
    Logan, Qld
    Magnetic DEMCI filters would work though.
    Groff likes this.
  19. terrastrife
    terrastrife Member
    Jun 2, 2006
    18,495
    ADL/SA The Monopoly State
    a narrow case limits your GPU selection to pretty much low power GPUs as you can't fit the power cable.
    If you don't need more than 32GB of RAM on a consumer board, go ITX. That opens up a whole load of narrow upright cases (less than 10cm) with no limitation on graphics cards for the most part.
  20. pwlm1975
    pwlm1975 Member
    Apr 18, 2016
    366
    Logan, Qld
    OP already has an mATX setup, they're just looking for a new case.
