Why do phones light up randomly these days?
Discussion in 'Mobile Phones & Devices' started by ricee007, Oct 9, 2007.
  1. ricee007
    ricee007 Member
    Sep 4, 2004
    6,574
    Radelaide
    As per thread title?
    What is it doing, can I turn it off? It is particuarlly annoying....
    R
  2. Aratama_Bashi
    Aratama_Bashi Iron Photographer
    Jan 19, 2007
    7,212
    Tallinn, Estonia
    zOMG phone make and model or help = 0
    ricee007
    ricee007 Member
    Sep 4, 2004
    6,574
    Radelaide
    Cmon, hows your memory;)?
    Sory, didnt include Make/Model as it happesn on my sistas fone, and someone once explained why, and it also happens on my phone. (We forget why it was explained though)
    6120 C
    6110
  4. Szemen
    Szemen Member
    Sep 20, 2005
    1,079
    In general, alot of phones are light sensors. Then they light up the screen if their isnt enough of in the surrounding so there will be little viewing problems.
  5. elephantman
    elephantman Member
    Feb 26, 2002
    1,605
    2111
    Mine doesn't light up randomly but it lights up when it auto locks, thats annoying :p
  6. salmon
    salmon Member
    Mar 23, 2006
    1,230
    2227
    my bros and my mums phones light stays on full when the charging there samsungs
    ricee007
    ricee007 Member
    Sep 4, 2004
    6,574
    Radelaide
    Hm, no, the phone will just be sitting on my desk, not being touched for ages and it will randomly light up for a second and go back dark...
    The explnation given (that im not happy with:p), is that it irs updating the cell info display...
  8. muv
    muv Member
    Apr 6, 2003
    223
    i have a 6120c and i think it lights up after a timeout when it goes into screensaver mode...maybe its autolocking at a point...something like that
  9. Kow
    Kow Member
    Aug 2, 2001
    4,790
    Redlands, Bris QLD
    It lights up when finished charging or low battery usually :)
  10. Aratama_Bashi
    Jan 19, 2007
    7,212
    Tallinn, Estonia
    oh knoes! battery = low! light up to full power, play a max volume alarm, and turn on bluetooth to alert any devices nearby, make a data connection to home server, and fire up wifi just to be sure!!! :p
  11. T-O-D
    T-O-D Member
    Oct 23, 2003
    1,317
    Brisvegas!
    I know my phone (LG u880) lights up with alarms. Even if I've set an alarm, and then deleted it, it will still light up. It normally only happens once per alarm, but i normally only set "today only" alarms, not "each day of the week" alarms.
  12. daiduong24
    daiduong24 (Banned or Deleted)
    Jun 12, 2007
    76
    sometimes you can just go to the setting, and change the backlight setting, that might help the randomnese:leet:
  13. BRGMCS
    BRGMCS Member
    Oct 28, 2005
    2,665
    you may not be happy with it, but it's correct :D
  14. thrillhouse
    thrillhouse Member
    Mar 3, 2002
    1,825
    sydney sydney sydney
    I guess it lights up whenever something changes on screen, just in case at that precise moment you are in a dark room looking at your phone. I guess this makes sense as to why it would light up when changing cell towers.
    Haven't noticed mine light up randomly. Nokia 6300
  15. dink
    dink Member
    Feb 15, 2002
    7,480
    Brisneyland
    My Nokia E61 lights up at random. It seems to happen when it drops or establishes connections. Never been quite sure why it does it. Very annoying it is.
  16. rade
    rade Member
    May 3, 2002
    346
    My 6085 lights up randomly too, for no apparent reason. I just thought it was a glitch of some sort
  17. chicken-
    chicken- Member
    May 2, 2005
    664
    Fortitude Valley, QLD
    Most Nokia and Motorola phones light up when the Cell Info Display (i.e. the text that shows that suburb/locations phone cell you're on) changes, since most mobiles like to jump around between local cells, this usually causes the stupid backlight to turn on and off all night.
    It does this because the location text is sent as a info service, and the phone lights up just as if it received a normal push message.
    Disable Info service/cell info display reception in messaging config to stop it. :D
  18. kimnkk
    kimnkk Member
    Jan 20, 2004
    2,426
    Me!bourne
    My Nokia 8800 will light up briefly when it has dropped a 'bar' of battery.
    ricee007
    ricee007 Member
    Sep 4, 2004
    6,574
    Radelaide
    Cheers champ!
  20. Draco
    Draco Member
    Dec 29, 2001
    401
    My 6021 does this too. When the phone isn't in use it just shows the time on a grey background with icons for silent mode, missed calls and messages. Sometimes it lights up without this changing. No incoming messages, doesn't go to the main wallpaper screen or anything.
    I have cell info display disabled too so it's never shown up. I call it's just crappy Nokia software. /me pines for his Sony Ericsson again.
