Will my power supply be big enough
Discussion in 'Overclocking & Hardware' started by Gaddo, Jun 21, 2011.
  1. Gaddo
    Gaddo Member
    Jul 21, 2010
    23
    Hi Guys very new to this but just wondering i have a antec 850w psu
    and want to and a few things to my case.
    at the moment it has
    i7 920
    gigabyte X58A-ud3r
    the unit has a dvd-rom
    and a MSI GTX560ti hawk GPU
    and 3 hard drives they are
    1x WD 1tb sata
    1x solid state drive 64gb
    and a 300gb sata drive
    now what i want to add is the following
    an extra MSI GTX560ti hawk card running in SLI
    and i know i may get flamed but i want to also add a
    coolit vantage cpu liquid cooling unit to start to play around some more with over clocking as it is overclocked to 3.3ghz atm
    so just need to know will my power supply be able to cope ?????
    thanks for your advice
    Gaddo
  2. Spyfox
    Spyfox Member
    Nov 28, 2010
    1,270
  3. King Krapp
    King Krapp Member
    Jan 19, 2009
    2,639
    850w is fine for a 560 SLI + WC system, assuming it's a decent Antec. What model do you have?
    Gaddo
    Gaddo Member
    Jul 21, 2010
    23
    hey guys thanks for the reply the psu is a antec truepower Quattro 850w
    all this is also in an antec 902 case so it has a few fans that in runs aswell thanks again
    Gaddo
  5. Sven76
    Sven76 Member
    Aug 7, 2002
    1,436
    Bundaberg
    I have
    17 920 (3.2)
    CD ?DVD rom
    3 x 500 gig in raid 0 for os
    2 x 500 gig in raid 0 for games
    (so gaming 5 drives running)
    2 x Gigabyte gtx 560ti's (sli)
    8 case fans
    water pump
    fan controller
    under load gaming it upsets my 530watt ups if have a monitor plugged into ups at same time
    This is running on a Thermatake 875watt PSU
    so im drawing about 500ish watts
  6. King Krapp
    King Krapp Member
    Jan 19, 2009
    2,639
    The Quattro line is good. You'll be fine :thumbup:
    Gaddo
    Gaddo Member
    Jul 21, 2010
    23
    you guys are fantastic thanks for the advice it is greatly appreciated
  8. WishBone17
    WishBone17 Member
    Nov 21, 2002
    4,514
    Dundas (Sydney)
    my bro is using a Corsair 850w PSU to power 2 x GTX 580 and i7 2600K + 3 x 1 TB HDD and his GPU/CPU is oc'd quite heavily.
    So yeah your PSU is more then enough, but if i was you, id get a 1Kw PSU and a third 560 :)
    EDIT: do 560 do triple?
  9. Sven76
    Sven76 Member
    Aug 7, 2002
    1,436
    Bundaberg
    Nope +10..
    Gaddo
    Gaddo Member
    Jul 21, 2010
    23
    i am new to the overclockers forum and overclocking it self have just been reading som e of the things you guys are doing its insane lol
    if i had the cash i would do the triple 560's but i think 2 will be enough for me thanks guys
  11. Sven76
    Sven76 Member
    Aug 7, 2002
    1,436
    Bundaberg
    If you are thinking you want to go triple you cant get 560's :( they will only do 2 x sli .... i think the 580 is the one you want to go triple
  12. Linkin
    Linkin Member
    Apr 25, 2010
    6,389
    Argh that thing is terribly inaccurate. It suggested 350w for my sig rig as it is now.
    If you want to find accurate numbers, find the TDP of each major component and add them up, that will give you a rough estimate on wattage, leave 150w-200w of headroom for overclocking and misc hardware like RAM, HDD etc
  13. brayway
    brayway Member
    Nov 29, 2008
    6,854
    New Zealand
    4/570 and 4/580 can do triple, that's out of the current gens :thumbup:
    and I think the 4/5/0 and 590s can do quad :)
  14. digsy
    digsy Member
    Apr 30, 2011
    106
    Seven Hills, NSW 2147
    haha...thanks for the plug bro :) oced my 2600K to 5ghz no probs...
