Will my PSU die?
Discussion in 'Overclocking & Hardware' started by spotted, Apr 16, 2019 at 3:41 PM.
  1. spotted
    spotted Member
    Nov 10, 2010
    331
  2. adamsleath
    adamsleath Member
    Oct 17, 2006
    13,073
    Sunnybank Q4109
    depends on the noise. maybe the fan (its a ball bearing type and they can go dry or wear out). maybe something else.
    if you take out the fan and try oiling it. rp7 or singer oil or somesuch. dont want it to drip on the components, but ive read that some people do this with some success. and others without success.
  3. asho444
    asho444 Member
    Feb 7, 2012
    794
    Sunny Coast
    spotted
    spotted Member
    Nov 10, 2010
    331
    Wow I didn't know it was released 2005. I'm surprised the connectors work with my mb and gpu!
    I guess I just know very little about how to choose a PSU, and what connectors I need etc. I want a low wattage to make use of the peak efficiency right?
  5. adamsleath
    adamsleath Member
    Oct 17, 2006
    13,073
    Sunnybank Q4109
    that's the rule of thumb. 450-550W supplies are all most people need.
    even less.
    therell be a bunch of opinions, always open to suggestions.
    rm550w corsair is a nice one. (80plus gold) overkill but a nice warranty and quiet operation.
    there are others.
    the small form factor psu's from corsair are highly regarded by some.
    SF450 for example. 7yr warranty.
    spotted
    spotted Member
    Nov 10, 2010
    331
    I am keen on quiet. I sit next to my PC. Even tho I supposedly have quiet case fans I can hear the wind.
    So many ATX PSU are high powered. I have ATX case/MB, does that mean I can't use SFX/TFX form factors? They'll leave holes in the back of the case?
  7. adamsleath
    adamsleath Member
    Oct 17, 2006
    13,073
    Sunnybank Q4109
    yeah. adapter bracket required for sf.
    i think the 550 one has a fanless mode. the tests show it is quiet. "virtually silent at low to medium loads"
    fanless psu's are usually expensive.
    2 cents :)
    bitfenix do a "whisper m 450W" but hard to find in australia.
    antec ea 450w also hard to find....mm discontinued...owell.
    https://www.umart.com.au/SeaSonic-5...xuRhqFPzRPRb_Gi7I3fHx0IRFtzs_hpoaAoPyEALw_wcB
    slightly cheaper; 7 yr warranty.
    https://linustechtips.com/main/topic/631048-psu-tier-list-old/
  8. Myne_h
    Myne_h Member
    Feb 27, 2002
    8,357
    https://www.xoticpc.com/coil-whine
    Most likely. Not dangerous or indicative of failure.
    Still, a new PSU is pretty cheap. No harm relegating the current one to "spare".
    spotted
    spotted Member
    Nov 10, 2010
    331
    Set my beard. I tried to open the case to see where it comes from but it's so high pitched I can't really be sure. But I noticed that as soon as I press shut down the sound stops , even before the computer actually shuts down. It seems to also leak audio to my speakers.
  10. adamsleath
    adamsleath Member
    Oct 17, 2006
    13,073
    Sunnybank Q4109
    coil whine?
    um can you pin point where the noise is?
    sounding less like it is the fan...
    make a little vid of it on your smart phone maybe....
    just have to use your ears...close to each part. be careful not to touch them of course :p
  11. Myne_h
    Myne_h Member
    Feb 27, 2002
    8,357
    Get a thin tube and make yourself a ghetto stethoscope
  12. EclipZ
    EclipZ Member
    Mar 11, 2002
    113
    bne.qld.au
    Old Antec Neo HE 430 is likely a rebadged Seasonic anyway, you could lookup the UL No. on the side of the PSU if interested.
    +1 for getting the SeaSonic 550W Focus Gold to replace it anyway - to go with the rest of the nice new system and keep the old Neo as a spare.
    I got about 8 years out of my old NEO HE 550 before it went bang, when it died it didn't kill any other components though.
    As to the noise, does it sound something like what's in this video?
    particularly like with the pitch changes between about 0:13 and 0:19
  13. havabeer
    havabeer Member
    Dec 12, 2010
    4,478
    The same can be said for your psu
    Myne_h likes this.
    spotted
    spotted Member
    Nov 10, 2010
    331
    Really getting close I'm pretty sure it's not the GPU. It does seem more like coil whine, it's kinda similar to what EclipZ posted.
    It's higher than the GPU, so that's either the CPU area or PSU.
    I have oiled the PSU fan anyway, it didn't make a difference.
    Sometimes the whole rig runs silent, sometimes it does that whine. Could it be software triggered? In any case I'm looking at a new PSU. Nice easter break eh.
  15. adamsleath
    adamsleath Member
    Oct 17, 2006
    13,073
    Sunnybank Q4109
    as you're fairly convinced it is psu.
    just take it out of the case. and do a test. sit the psu outside the case. connect the power to the motherboard and gpu and fire it up. should make the noise easier to isolate.
    spotted likes this.
    spotted
    spotted Member
    Nov 10, 2010
    331
    Looking at the
    be quiet! Pure Power 11 500W CM which seems to say it's quieter but it's 2cm longer
    vs Seasonic SSR-550FM Focus 80+ Gold since I don't think there's much time I need the fanless mode of the plus for +$20.
  17. Bold Eagle
    Bold Eagle Member
    Jun 28, 2008
    8,344
    It is so easy to test.
    - Open side of case,
    - Turn PC on,
    - Stick a toothpick into the PSU fan (or something wooden like a skewer, chopstick - DO NOT USE METAL) and stop it, does fan noise stop?
    Fan bearings do dry out, get old and or just start to whine a bit.
    It is 'very simple' to fix to either lube the fan or just swap it out of the PSU.
    Don't waste money on new gear unless you like to.....................
  18. EclipZ
    EclipZ Member
    Mar 11, 2002
    113
    bne.qld.au
    Youtube video was just a decent example of coil whine I could find (based on what I've heard personally for noisy coils) to see if that was the same noise you are hearing, not necessarily pointing at video card as the source.
    Yes it could be software dependent - in so far as coil whine should be more pronounced when the system or particular component with the vibrating coil(s) has more load.
    Running a Linpack stress test might help make the noise consistent and help track it down if the noisy coil(s) are within the PSU or on the mainboard, as would taking the parts out of the case and running with minimum components to isolate.
