Winchester (A64 939 90nm) Overclocking Results and Discussion
Discussion in 'AMD x86 CPUs and chipsets' started by Danthemanz, Nov 22, 2004.
  1. Danthemanz
    Danthemanz Old School Admin
    2,436
    I thought we needed a thread just for the winchester overclocking results.
    Other threads are for specificaly for ranks etc, this is to see how good the winchester actually is and discuss cooling/voltages etc...
    This is the Socket 939 3000+, 3200+ and 3500+ 90nm (Dont know if they are in Aus yet).
    Please post your Overclocks, temps, voltages, stepping, cooling and what you tested stabilty with...
    At this stage im running my 3200+@ 2.5ghz@1.47V using a TT Polo735, ive run a few 32M superpi, a bit of stressCPU and video encoding for 6 hours last night with no issues. Still early days...
    What are people getting for temps?
    Edit: Fixed temps.
  2. Chamelion
    Chamelion Member
    Dec 31, 2001
    11,044
    Strathpine, Brisbane.
    Running my 3200+ @ 2.5ghz 1.45v, stable for normal use. Unstable for number crunching however.
    My board seems locked at 1.45v unless I choose 1.6v, which it does go to 1.6v at... This however caused mid-high 50's load temps with my XP-120 and Sunon 120cfm on SLOOOW (but quiet) speed.
    I am hoping a future bios update will correct this issue. I do believe my CPU would do this speed at 1.5-1.525v
    Matt.
  3. jlccarv
    jlccarv Member
    Dec 29, 2002
    1,134
    Thats 5c over the max rated temperature. You should fix that ASAP...
    Run StressCPU to test for the stability of your CPU overclock. If your 3200+ is stable 2.5GHz, with only 1.47v, you have a bloody great chip on your hands :thumbup:
  4. jlccarv
    jlccarv Member
    Dec 29, 2002
    1,134
    Use clockgen from windows, to set the voltage core. On my machine the voltage sticks, even after restarts/shutdowns etc...
    I use it for its 0.25v increments/decrements, as my BIOS only allows for changes in 0.5v
    Danthemanz
    2,436
    Yeah i have run it StressCPU(for a short period) but my temps are getting too high to run it for too long, looks like its going to be stable once i get my temps down...
    Yeah i think ive done well, had it at 2600@1.57 appeared stable (but too hot to burn it in)
    Still early days...
  6. ysk
    ysk New Member
    Jan 26, 2003
    225
    I've got my 3200 running at 230x10 on stock volts and it idles at low 30's and peaks at around 40c :)
    Seems that this chip needs atleast 1.55v for 2.4 and above to be prime stable otherwise it errors after like 4 hrs.
    Still 300mhz for free on stock volts doesnt seem too bad :thumbup:
  7. Chamelion
    Chamelion Member
    Dec 31, 2001
    11,044
    Still a 3700+ or thereabouts :p
    Matt.
  8. DeCan
    DeCan Member
    Jan 2, 2002
    167
    SYDNEY
    Hi Guys,
    I have my 3200 running at 2560mhz 10x256 seems stable. Running 3dmark05 a number of time. Low score tho 5960 I think it was.
    I have stock cooler for now but I have aircon in the room.
    Temps are between 30-39C idle and 49-54C full load... the temp jumps around a lot tho.
    I have a vapochiller but it wont boot with this board, seems that a lot of vapochiller users are having this problem, so I'll have to wait for a bios update.
    I have a better cooler on the way so I should have that by tomorrow or the day after.
  9. Chamelion
    Chamelion Member
    Dec 31, 2001
    11,044
    3200+, ASUS A8V Deluxe, Geil 2x512mb Ultra Platinum PC3500...
    260x10 (ram at 218 2-3-3-6 1T) 1.6vcore
    Thermalright XP-120 w/Sunon 120cfm @ 45 load currently.
    Seems stable, will run through super PI fine for 34 seconds.
    Matt.
  10. trop
    trop Member
    Jan 14, 2004
    3,433
    3000+, SN95G5 shuttle, 2 x 512 kingston HyperX ULL (borrowed, my corsair 3200xl will be here by friday I hope)
    278 x 9 (2501) 4x @ 1.65v with loose timings is prime stable
    280 x 9 (2520) 4x @ 1.65v, 5:6 2,2,3,6 is stable for games, dvdshrink, etc and runs superpi to 1m in 33s
    I'v run out of htt and voltage in the bios, with clockgen I can go higher htt but without more volts I can't stabilse it for anything. The shuttle cooler kept it under 50C at full load when we had a 38C day here last week.
  11. inkerek
    inkerek Member
    Nov 1, 2004
    894
    SE Melbourne
    Holy shit, what motherboard and cooler trop ? That is extreme.
  12. aokman
    aokman Member
    Jul 12, 2001
    12,453
    I just brought one of these today, it will be going on the waterchiller shortly :)
  13. GSX-R
    GSX-R Member
    Nov 29, 2002
    981
    Melbourne, Australia
    With a Neo2, i'm running my 3200+ @ 2.6GHz at the moment.. 1.600v
    board runs htt up to 330mhz .. probably get an OCZ booster for the PC-4400 next week so i can run at least 320 htt in sync 1:1
    Cooling for cpu is XP-90 with vantec tornado running through hardcano 9 controller / lowest speed...
    chip is good for 2,750 on air, not prime stable though.. but stable for overnight loop of 3dmark01 etc.
  14. aokman
    aokman Member
    Jul 12, 2001
    12,453
    Heres what i managed 290x10
    It locks at the load screen to windows at 3ghz :( i have a hunch its the mainboard....
    Its a little iffy at the moment though, im pritty sure the HTT is crapping out on the mainboard as it wont prime even at 9x multi @ a previously stable clock speed.
  15. dukkie
    dukkie Member
    Oct 9, 2002
    1,742
    fark.....VERY VERY NICE!!
    also wat board and cooling u using? also ram :p
    cheers
  16. aokman
    aokman Member
    Jul 12, 2001
    12,453
    Using an ASUS A8V mobo with Corsair 3200C2 memory (obviously i have to use dividers as it can only do about 240FSB). I was actually shocked that the bios only goes upto 300HTT :confused: it has to be the board though as a 9x multi drops the CPU clock to like 2500 which is stable but not with a high HTT.
    Heres the thread for the cooler im using, its a waterchiller :) at stock speeds i managed -20c with this CPU
    http://forums.overclockers.com.au/showthread.php?t=324796
    Heres the Sandra score also:
    What board do you have, 330HTT would be sweet :)
  17. dukkie
    dukkie Member
    Oct 9, 2002
    1,742
    omg ur cooling is insane....but wayyyy 2 much lol,
    i using the msi k8n neo2 plat and its workin at 10x254 (254htt) and yeh its goin fine wit 1.57volts...
    my ram was limiting me abit so i just usin the 5:6 divider (ram is ocz 3700eb) so im pretty happy with my o/c, wouldnt mind 2.6ghz though :)
  18. aokman
    aokman Member
    Jul 12, 2001
    12,453
    I am running 2.5GHZ at the moment @ 1.6v at 2.6GHZ it craps out in prime with a hardware failure no matter what voltage so i know its the mobo dieing at 260HTT, it just gets worse as i go higher but just enough to get into windows. May have to look at the MSI, its the only 939 board i havn't tried yet ;).
    No chipset voltage options on this board :( and the HTT multiplier is very weird. At 4x290 it goes into windows but at 3x290, it wont :confused: but it should work better :lol:
  19. dukkie
    dukkie Member
    Oct 9, 2002
    1,742
    well i was running mobo at 292htt no probs b4, but that was using 292x9 so i decided to just use the x10 multi...
    but yeh its a really good board imho
    give it a try, u got nothin 2 lose :p
  20. aokman
    aokman Member
    Jul 12, 2001
    12,453
    Oh dont worry, im going to get to 3.0GHZ no matter what it takes :)
