Windscreen mounts for phones
Discussion in 'Mobile Phones & Devices' started by Stooge007, Mar 21, 2015.
  1. sanjay
    sanjay Member
    Mar 10, 2004
    16,197
    Coburg, Melbourne
  2. Sankari
    Sankari Member
    Jun 13, 2009
    32,175
    Adelaide, SA
    Same. Makes perfect sense and keeps it out of the way.
    Stooge007
    Stooge007 Member
    Aug 22, 2006
    11,972
    The Shire, Sydney
    do you worry that the mount might fall off and the phone fall out an open window?
    my (many years old) GPS suction mount has a nasty habit of falling off :thumbdn:
  4. SupremeMoFo
    SupremeMoFo Member
    Sep 8, 2007
    5,006
    Nah. The Logitech mount has a really aggressive suction cup, it's not going anywhere.
    Stooge007
    Stooge007 Member
    Aug 22, 2006
    11,972
    The Shire, Sydney
    anyone with a Logitech Drive+ have any spare universal adaptors (the little metal squares) they want to sell?
    PM me pls :)
  6. xplod140
    xplod140 Member
    Jun 1, 2002
    4,663
    Melbun
    I got something similar from Amazon although mine just clamps, no screw.
    Good enough to hold an iPad mini.
  7. << J o Y i >>
    << J o Y i >> Member
    May 9, 2003
    831
  8. Kow
    Kow Member
    Aug 2, 2001
    4,792
    Redlands, Bris QLD
    I need a mount where the suction cup doesn't die after a couple of months.
    Stooge007
    Stooge007 Member
    Aug 22, 2006
    11,972
    The Shire, Sydney
    i bought the Logitech +drive system, and as long as you start with a clean surface (i cleaned mine with an alcohol swab), i don't think the suction cup is going anywhere anytime soon
  10. Kow
    Kow Member
    Aug 2, 2001
    4,792
    Redlands, Bris QLD
    It's mainly the heat which buckles and distorts the cup. So maybe they might have a better design.
    Stooge007
    Stooge007 Member
    Aug 22, 2006
    11,972
    The Shire, Sydney
    so i ended up with 2 Logitech Drive+ and after a couple of years, they both now fall off the windscreen, no matter what i try
    anyone have any suggestions as to how to get them to attach better?
    i do like the magnetic style
    otherwise might try the CD loader holder, or the iottie gear
    is there anything out there better right now?
    cheers
    EDIT - anyone tried these - https://www.officeworks.com.au/shop/officeworks/p/3sixt-neo-mount-black-cn3s0242 ?
    i see officeworks still sell the Logitech Drive, i'd avoid :(
  12. Beanz
    Beanz Member
    Sep 11, 2002
    1,201
    Melbourne, Vic
  13. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    161,658
    Omicron Persei 8
    Exactly what I use also, cheap and effective.
    Stooge007
    Stooge007 Member
    Aug 22, 2006
    11,972
    The Shire, Sydney
  15. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    161,658
    Omicron Persei 8
  16. MaximusSmurf
    MaximusSmurf Member
    Sep 8, 2004
    853
    You guys seen any good qi wireless charging mounts? Does my head in plugging the cables in. I've had two different air docks but the both broke in different ways. And we're damn expensive.
  17. MR CHILLED
    MR CHILLED D'oh!
    Jan 2, 2002
    161,658
    Omicron Persei 8
    What sort of thing are you looking for? There's a few ways to do it.
  18. MaximusSmurf
    MaximusSmurf Member
    Sep 8, 2004
    853
    Just something to hold a phone. Suction or vent. And have inbuilt qi for charging. So I don't have to constantly plug the cable into the phone.
  19. Zee
    Zee Member
    Oct 27, 2002
    12,001
    SYD/MNL/SIN/SFO
    A bit late, but I've bought a Baseus vent mount from Aliexpress, cost about $12 or so shipped, and has been better than the logitech version (which costs about double). Also looks nicer.
    Having said that, my suction cups still work after all htese years.
    Z...
  20. xplod140
    xplod140 Member
    Jun 1, 2002
    4,663
    Melbun
    I've had the cd player slot mount for 3 years now I think? I really like it a lot better than any suction mount as it's always there, no need to fiddle and get fingerprints on everything etc. It's also less distracting and easier to reach IMO. Also fits a small tablet if need be.
    Only downside is I think I will possibly break a finger trying to pull the lever to get it out, it's really secure at least.
