windwithme's LGA 1156 review part5-DFI LANParty DK P55-T3eH9 Overclocking test
Discussion in 'Intel x86 CPUs and chipsets' started by windwithme, Dec 25, 2009.
  1. windwithme
    windwithme Member
    May 11, 2007
    863
    LGA 1156 is the latest Intel platform which announced two months ago.
    P55 is the first chipset designed for the new platform; and at this moment, there are three LGA 1156 CPUs in retail,
    Core i5-750, i7-860 & i7-870. By following Intel’s marketing segmentation, almost every MB manufacturers launched P55 product for mainstream to mid-high market.
    DFI LANParty launched P55 later than other brands; finally, we found DFI P55 in market in the end of October.
    Recently, we also heard some news about DFI’s P55 in mini-ITX form factor, maybe DFI want to create a different segment for P55?
    The product I review today is DK version, the mid-range product in LANParty series.
    The full marketing name is “DFI LANParty DK P55-T3eH9”. (DK P55 for short).
    You can find blue & black color on package; DFI adopts this pattern since early 2009.
    Accessories
    User manual, ABS manual (auto overclocking), DVD driver disc, I/O shield, Crossfire & SLI bridge, USB cable (for BIOSecure function).
    DFI LANParty DK-P55 T3eH9
    Bottom left of DK P55
    3 PCIe, supports 2-way CrossfireX & SLI with Physics (Bandwidth: x16/ x4/ x0 or x8/ x4/x8)
    2 PCIe x1
    2 PCI
    Intel 82587DV GbE LAN, Debug LED
    Realtek ALC 885 for 7.1 channels HD audio
    Bottom right of DK P55
    6 SATA II connectors in orange (RAID 0/1/0+1/5 function from P55 chipset)
    2 SATA II connectors in black (RAID 0/1 function from JMB322)
    Power/ Reset buttons
    Upper right
    4 DDR3 DIMM in Dual channel architecture; ready for DDR3 1066/ 1333/ 1600/ 1800(OC); max capacity is 16GB (4G x 4)
    You should OC DDR3 to reach 1800MHz. You can also find 24-pin DC in connector here.
    Upper left
    LGA 1156 socket
    PWM: 6 phase for CPU, 2 phase for VTT, 1 phase for the incoming Clarkdale.
    I/O
    4 USB 2.0
    1 power eSATA/ 1 USB 2.0
    1 optical/ Coaxial S/PDIF
    1 RJ-45 LAN port
    1 Clear CMOS button
    1 mini USB port for BIOSecure
    Cooler module for DK P55
  2. uberbanzai
    uberbanzai Member
    Jan 4, 2003
    3,388
    Might want to fix up the title ? Or am I reading it wrong ?
    windwithme
    windwithme Member
    May 11, 2007
    863
    There is an extra fin module in middle for enlarging the surface for better heat dissipation.
    Cooler module for MOSFET; DFI indeed improves the cooler quality for DK series.
    Tantalum Capacitor for audio
    “Solid capacitor” produces “artificial” sound, so DFI adopts Tantalum cap in audio circuit.
    The memory bandwidth of P55 is less than X58 because the dual channel architecture.
    Boot up screen
    BIOS menu
    It’s the first time DFI adopts AMI BIOS. You can choose the language you want when log in BIOS menu.
    OC main menu
    Options for CPU
    Voltage setting page
    O.C. Shut Down Free: DFI patent technology; no “turn off the power” needed when changing the voltage.
    CPU Voltage 1.0000~2.0000V
    Power Saving Standard means turn ”Vdroop” off; Advance means you allow voltage droop
    Super VID ON means lock down the voltage when enabling EIST/C1E.
    CPU VTT Voltage +0.05~+0.697V
    DRAM Voltage 1.20~2.60V
    CPU/DRAMCOMP: When enabling this option, you can get 1~5MHz higher in bclk.
    windwithme
    windwithme Member
    May 11, 2007
    863
    DDR3 setting in detail
    CMOS RELOADED: there are four banks for saving customized profile.
    PC status
    This is my BIOS setting screen capture.
    The potential of OC is depending on CPU quality.
    Even you get two or more i5-750 which was produced in the same time, the OC result will be totally different.
    So, you have to adjust frequency & voltage carefully to get the best result.
    Configuration
    CPU: Intel Core i5-750
    MB: DFI LANParty DK-P55 T3eH9
    DRAM: CORSAIR DOMINATOR-GT CMG4GX3M2A2000C8
    VGA: GIGABYTE GTX260 OC
    HD: CORSAIR CMFSSD-64GB2D (RAID 0)
    POWER: be quiet! STRAIGHT POWER DELUXE 550W
    Cooler: Tuniq Tower 120 Extreme
    Cooler Tuniq Tower12 Extreme ,Hi-end solution for air cooling.
    Cooper made basement; five heat-pipe in both left & right side.
    CPU 200 X 20=> 4000Mhz 1.34V
    DDR3 2000 CL8 8-8-25 1T 1.53V
    Hyper 4 X PI 32M=> 9m 52.359s
    CPUMARK 99=> 622
    Nuclearus Multi Core => 24715
    Fritz Chess Benchmark => 24.71/11858
    CrystalMark 2004R3 => 294022
    CINEBENCH R10
    1 CPU=> 5577
    x CPU=> 20345
    windwithme
    windwithme Member
    May 11, 2007
    863
    PCMark Vantage => 15482
    DK P55 performs stable in 200/ 2000MHz.
    To compare with other P55, there is no difference in voltage setting.
    OC performance is better than average.
    DDR3 bandwidth
    DDR3 2000 CL8 8-8-25 1T,1.53V
    Sandra Memory Bandwidth - 24479MB/s
    EVEREST Memory Read - 18567MB/s
    DDR3 2100 CL8 8-8-25 1T,BIOS 1.63V
    Sandra Memory Bandwidth - 26008MB/s
    EVEREST Memory Read - 19645MB/s
    Memory bandwidth of DK P55 is a little bit higher than others. However, the frequency reaches 2100MHz only.
    I hope that DFI can break through the bottleneck and release new BIOS for overclocking.
    Software bundling is the weakness part in DFI product.
    Finally, DFI adds some useful tools for P55 series such as Auto-boost, bclk OC & BIOSecure.
    BIOSecure let you recover BIOS when crashing.
    Generally, you have to send the board back when BIOS is crashed; with BIOSecure, you can recover it by yourself immediately.
    If your board cannot boot anymore, you can user BIOSecure on the other PC or NB as “BIOS programmer”.
    Simply “install” the new BIOS via mini USB port, your board with be fully recovered within 1 minute.
    Then, let’s try higher bclk and DRAM frequency
    CPU 210.8 X 20 => 4216Mhz
    DDR3 218 CL8 8-8-25 1T
    Hyper 4 X PI 32M=> 9m 24.406s
    CPUMARK 99=> 653
    Nuclearus Multi Core => 25975
    Fritz Chess Benchmark => 25.89/12425
    CrystalMark 2004R3 => 305172
    CINEBENCH R10
    1 CPU=> 5966
    x CPU=> 21375
    PCMark Vantage => 16052
    CPU works stable in bclk 210.8MHz, it could be higher if you enable “CPU/DRAMCOMP”.
    When OC to 4.2GHz, it still passes the test. Of course, if shows the OC performance.
    windwithme
    windwithme Member
    May 11, 2007
    863
    Okay, now let’s try the hi-performance gadget “CORSAIR CMFSSD-64GB2D (RAID 0)”.
    To test the SATA data transportation.
    Some people concern about the SATA transmission because P55 is a “Single chip” chipset.
    After the test, we can found the data transmission is almost the same with LGA 775 platform.
    Plus
    1.New cooler design. Good looking & good quality!
    2.SLI & CrossFireX ready, bundled with SLI/ CrossfireX bridge.
    3.All made in Japan capacitors; Tantalum capacitor for Audio; Intel 82578DC GbE LAN
    4.Various BIOS options; wide range for voltage setting; outstanding CPU/ DDR3 OC
    5.8 SATA II & 1 power eSATA
    6.Patented BIOSecure technology.
    Negative
    1. To OC Bclk to 220MHz would be better.
    2. To cooperate with more retail store, users can buy DFI product easier.
    3. Orange slot & connector should be changed.
    Performance ★★★★★★★★☆☆
    Quality ★★★★★★★★☆☆
    Specification ★★★★★★★★★☆
    Appearance ★★★★★★★★☆☆
    Price/ Performance ★★★★★★★★☆☆
    DFI will launch mini ITX P55 soon, which named “MI P55-T36”.
    I think DFI is trying to leverage the advantage from IPC department in order to find a new way out.
    The quality and cooler design is outstanding in DK P55,
    if DFI can release new BIOS for better OC, the Price/ Performance ratio would be very attractive.
    Here comes my DK P55 ABS file for your reference.
    If you have similar hardware with me, maybe you can try my setting.
    Wish you will get a nice overclocking!
    windwithme DFI LANParty DK-P55
  7. brayway
    brayway Member
    Nov 29, 2008
    6,721
    Dun - New Zealand
    WOW good review!
    am wuite interested in the new 1156 platform, might be something to look into later on. i gotta upgrade my cpu lol.
  8. WishBone17
    WishBone17 Member
    Nov 21, 2002
    4,411
    Dundas (Sydney)
    Nice review, but i have to disagree with you on the orange slots and connectors. I really like em, something different.
  9. Alpha2k6
    Alpha2k6 Member
    Aug 30, 2006
    1,297
    Sweden
    + It looks really cool with this orange color theme..
    - zero USB3 and SATA3 ports.. and legacy PS2 contacts that is mostly irrelevant is a little dissapointing :thumbdn:
  10. eva2000
    eva2000 DDR1/DDR2/DDR3 Addict
    21,902
    Brisbane, Australia
    to each his own i prefer PS/2 as i'm on a quality KVM switch which is PS/2 the USB ones i tried sux hehe
    yeah i like the old orange scheme better. but the sata ports off-orange doesn't match!
    thanks WWM for the review.. will be testing the same board very soon as well http://i4memory.com/f80/preview-dfi-lp-dk-p55-t3eh9-data-corsair-gskill-p55-ddr3-21602/ :)
  11. stablez
    stablez Member
    Apr 8, 2006
    4,038
    Humidycrib
    Another to refesh or idea to whats around the corner.
    do all i5 750's clock to 200blck?
    this DFK is a neat P55 board.
    Nice one WWM..
