[WIN7] Wirless keyboard and mouse wont work during installation
Discussion in 'Windows Operating Systems' started by burrows, Jan 12, 2018.
  1. burrows
    burrows Member
    Mar 8, 2010
    191
    I have a G19 and a mouse. And both of these wont work when i try to do a installation of Windows 7. It will get up to the first dialog screen but i cant go any further due to the devices not working. In the bios the USB legacy is enabled. and the mouse also works in the bios.
    This the MB i have. https://www.asrock.com/MB/Intel/Fatal1ty Z270 Gaming K6/index.asp
    Anyone with suggestions i should try. Thanks.
  2. wullieb1
    wullieb1 Member
    Jul 9, 2013
    321
    burrows
    burrows Member
    Mar 8, 2010
    191
    I did try that but i was getting errors so i gave up. What about if i take out c ssd drive and put one in from my old computer with access to the files. I would then use the d drive to install the OS then access the files from the c drive and also put the drivers my documents folder. Then re install the os to original drive and ssd. Move all my files i need for the USB and Lan to the c drive. Reformat d drive and move back the files to d drive. So if i have to do a reformat in the future i will have the files. I know this is the long way round but it is the only alternative unless i call a tech which i don't really want to do as they cost too much. So would this idea work by taking ssd on the C drive replacing it my files and installing the os on the D drive.
  4. callan
    callan Member
    Aug 16, 2001
    4,414
    melbourne
    Zotac have a program that patches an ISO image of your Win7 install disk to natively support the USB3 ports during installation. I couldn't find it on a 2 second search but I've used it successfully. Wander around their (rather unintuitive) site and see what you can find.
    Callan
    burrows likes this.
    burrows
    burrows Member
    Mar 8, 2010
    191
    Thanks Callan
