WorkLog - 3ft Tank with 3D background
Discussion in 'Pets & Animals' started by Kosti, Sep 17, 2014.
  1. Kosti
    Kosti Member
    Aug 19, 2001
    1,396
    So after a long vacation and the daunting task to complete Yellow Jacket I turned to a number of fish tanks that I needed to do something with.
    Also the fact that while I was away I had a few friends babysit my various tropical fish who have now ask i take them back :weirdo:
    My 3ft Tanks to embark in the world of 3D backgrounds is one that grabbed from gumtree ages ago - sadly was not cheap but it had to be 890mm as most where over 900mm which will not fit in the place i have reserved - inside our fireplace which doesn't get used and is home to a possum :wired:
    The tank when bought from previous owner and there setup
    My goal is to not use Texas Holey Rock anymore in my tanks and use alternate material to create a landscape or background that I like with easy maintenance
    I'm not very creative but some of these have inspired me to have a go and doing something similar to these at the below link
    3D Landscaping
    One of my favorites DIY Aquarium Background By Kodey of Newcastle, Australia
    So off to start landscaping :Paranoid:
    Kosti
    Kosti Member
    Aug 19, 2001
    1,396
    Add Temperature Display - Its Gotta Look OEM
    My first quick mod was to hack in a temp probe
    Kosti
    Kosti Member
    Aug 19, 2001
    1,396
    Underground Filtering - Reverse Style
    Since I will not want to move objects around often and will want a sand type bottom I opted to go with a underground filtration but in reverse
    The idea of underground filtration has been around for years, but some believe that reversing the process could help eliminate waste bio products building up
    I plan attach an old setup i got years ago from a bulk buy and stick a power head on one end and block the other and push the water through the grid and back out into the substrate :thumbup:
    First was modding up the base of them so they all fitted in the tank and because i had lost all of the original right angle connected I had to improvise with what i found at Bunnings
    Compairing between original and homemade - Perfect :D
    Now I got my bottom filtration fitted into the tank and ready to move onto the next phase :thumbup:
  4. disco frank
    disco frank Member
    Mar 14, 2008
    1,954
    perth
    interesting idea on the reverse UGF....
    keen to see how it goes!
    keep us updated!
  5. BigDave
    BigDave Member
    Nov 12, 2007
    3,705
    ADELAIDE/5018
    Long Live "Yellow Jacket"
    I'm in for the ride :thumbup:
    Kosti
    Kosti Member
    Aug 19, 2001
    1,396
    Haha, yes my failure to deliver is high :weirdo:
    Well I did make some progress on the tank :shock:
    Kosti
    Kosti Member
    Aug 19, 2001
    1,396
    Shaping the landscape from styrofoam & polystyrene sheets
    So I went out and bought some different sizes to try and see which option I would take, one white stuff came from Clark Rubber the other from Foamex.
    After a little reading I heard that extruded polystyrene was the best to use as it doesn't break as easy or create as much mess and normal styrofoam, this is the yellow one
    I didn't take pix of the whole sheets of the extruded or the 40mm styrofoam, but here is the 10m
    Now to start shaping out some walls and cliffs
    The aftermath mess
    So now I will continue to make show shapes and start building on them and see how it starts to look and shape
    Kosti
    Kosti Member
    Aug 19, 2001
    1,396
    I should have taken ART up and school - i can't shape
    Using my trusty hotwire that I had to purchase from the USA - I should have made one!
    i start to cut out and shape what I think would look ok, so far I have come up with this for one side
    Next will be to see how they look inside the tank​
  9. mad_mic3
    mad_mic3 Member
    Jan 18, 2009
    2,348
    Nulkaba
    Hey Kosti
    Gets some of those Mexican walking fish, then gets back to Yellow Jacket;)
  10. BigDave
    BigDave Member
    Nov 12, 2007
    3,705
    ADELAIDE/5018
    Kosti
    Kosti Member
    Aug 19, 2001
    1,396
    Kosti
    Kosti Member
    Aug 19, 2001
    1,396
    Trial and fitting
    So I started trying to place everything in the tank to see how it looks and getting a feel for design and structure
    Needs some trimming and some changes that i will need to do like the lettering as made them a little bigger
    Thoughts, Feedback, some encouragement or criticism welcomed :D
  13. disco frank
    disco frank Member
    Mar 14, 2008
    1,954
    perth
    the lettering could make it look like a impression of atlantis!
    add some random roman numerals as well?? :p
    but you username? am i correct it means more to you than say other members on here?
    are you going to cover it in plaster/concrete mix?
  14. terrabyte
    terrabyte Member
    Oct 5, 2003
    3,065
    Syd, 2147, near Blacktown
    Very cool, looking forward to seeing the finished product!
    Kosti
    Kosti Member
    Aug 19, 2001
    1,396
    I was originally going to make a theme like Atlantis using these pillars but it got too time consuming
    As for the name, well yeah i may not go with it in the tank :lol:
    Thanks! I too am hoping I can get it finished :weirdo:
  16. disco frank
    disco frank Member
    Mar 14, 2008
    1,954
    perth
    those pillars would look cool as! :)
    go on do it :p
    Kosti
    Kosti Member
    Aug 19, 2001
    1,396
    Going to add an underground waterfall
    Well after playing around with different layers I am going to try my hand at a underwater waterfall
    Here are the first stages of the design :thumbup:
    Still got a long way to go, next up will be trying to figure out on how to light up the tank with LED
    I am looking to you fish heads for idea's and ways to run lighting :) Basically I am looking to light up the tree trunk (Drift wood) and all around the background and also have the hood fluro's as well
    What are some good leds that I can submerge and light it up ​
  18. NanoDuke
    NanoDuke Member
    Feb 4, 2007
    7,348
    Can you try making your own?
    Led + figure 8 insulated wire + heat shrink + silicon it all together.
  19. money_killer
    money_killer Member
    Apr 10, 2010
    2,345
    Sunshine Coast
    nice job
  20. grrrr
    grrrr Member
    Jun 30, 2001
    979
    Cornubia
    If your going to put lights below the water line .. make sure they have their own light switch.
    Light sources that don't come from above can cause fish to swim on a lean instead of up and down. Discus and angles especially.
    I would make a little led spot light to shine down on the tree trunk from above.
